401 - 406 of 406 Posts
Hope someone has an answer for me. I bought a used steering wheel from the junk yard and it already has both cruise control and audio remote installed but it has a total of 4 connectors: 2x20 pin connectors and 1x10 pin connector + 2 ground. Is this configuration correct OR was this a modified installation?
here is a picture of the connectors:
OK I have an update on this. I have been doing a lot of searching and reading and thanks to dpnvektor who has a link to electrical diagrams in the automatic climate control thread I think I have an answer. To complete the steering wheel audio control mod you need to purchase the control assembly 36770-SNA-A11 (2006) or 36770-SNA-A12 (2007). I don't think there is a difference between the two parts but they have different numbers. Next you need to install the 2 wires missing from vehicles without steering wheel audio controls. Basically you need to run 2 wires from the connector at the steering wheel to the connector at the audio unit. Here are some pictures of the connectors in question.
Steering Wheel Connector
Audio Unit Connector
The view of these connectors is from the back. So following the DIY posted in the link above you would need to remove the upper portion of the steering column shroud and the portion of the dash surrounding the audio unit/climate controls. Instead of purchasing the EX wiring harness and cutting/splicing wires together you only need to run the 2 wires shown from one connector to the other. This is all in theory for now as I haven't had the time to attempt this yet but I see no reason why it won't work. If anyone attempts this before me let me know how you make out.
So does anybody know if it’s the same for a 2009 4 door Civic with factory touchscreen, navigation?? I’m fighting that right this second so any info would be appreciated
que tal, tengo un civic ex 06 el cual solo cuenta con mandos de audio sin navegación, busque asta encontrar un volante 09-11 con mandos de audio más bluethoo y voz, pero mi radio china no reconoce los dos botones nuevos ( 📞 y 🎙) podrían ayudarme, por favor...
Looking to run 2 of these wires myself. Bit of an electrical noob
I understand that we can use AWG18 to 22 wires. But what type and size of wire terminals (pins?) do I use to fit into the 2 plugs? And will I need a crimping tool, or will pliers be okay?
