61 - 71 of 71 Posts
Discussion starter · #64 ·
Hi. Did you manage to make the cruise control work? I have also civic 2007 from qatar and i'm planning to do this.
Unfortunately some people are not able to get the cruise to set. I can't say for certain what the issue is with them. If there is no issue with the wiring, the switch itself or any of the components that were changed (clock-spring, brake pedal switch) then the tachometer may not have the function or the ECU may not have the function. if that is the problem, the only way to fix it is to get a tacho that's compatible and/or an ECU that is compatible and have them programmed to your civic. I can't assist any further without being there physically to diagnose the situation tho.
Discussion starter · #65 ·
Não consegui ainda! Fiz o que foi passado aqui, mas mesmo assim só acende o CRUISE MAIN e não aciona o CRUISE LIGADO
Uma pergunta rápida, quando liga o carro e o conta-rotações faz uma pequena verificação da luz, vê as luzes principal e de cruise control acenderem?
Eu fiz o teste de painel e tem todas as luzes necessárias para o Cruise Control
Discussion starter · #67 ·
Hey! Did you ever find out what the issue was?
If not, it may be that the ECU is not compatible. I think the cruise control functions are sent to the ECU via the Canbus, and if the ECU was never programmed for Cruise Control then it wouldn't know what to do with the cruise signals. Just a thought.
Olá! Já descobriu qual era o problema?
Caso contrário, pode ser que a ECU não seja compatível. Penso que as funções do cruise control são enviadas para a ECU através do Canbus, e se a ECU nunca tivesse sido programada para o cruise control, não saberia o que fazer com os sinais de cruzeiro. Apenas um pensamento.
So that means your steering wheel is on the right side of the car right? The steering wheel in my car is on the left side of the car. Maybe the civics with the steering wheel on the right side have the distribution box somewhere else in the car? That's why I recommended to check behind the glove compartment, maybe it's there. If not then your model probably just doesn't have one.
Well, let me know what you find.
Então isso significa que seu volante está do lado direito do carro, certo? O volante do meu carro está no lado esquerdo do carro. Talvez o civic com volante do lado direito tenha a caixa de distribuição em outro lugar do carro? Por isso recomendei verificar atrás do porta-luvas, talvez esteja lá. Caso contrário, seu modelo provavelmente simplesmente não possui um.
Bem, deixe-me saber o que você encontrou.
Volante do lado esquerdo do carro, assim como o seu!
E realmente não tem a caixa de distribuição.
Pelo que vi, toda a distribuição sai da MICU
Discussion starter · #69 ·
Yeah I remember you saying that before, very strange.
Do you think the issue is the ECU? Maybe it doesn't have the functionality for Cruise Control? Because everything else is working from what I can tell.
Can you take a picture of the numbers on your ECU? I can compare it to mine to see if it's different.
Sim, eu me lembro de você ter dito isso antes, muito estranho.
Você acha que o problema é a ECU? Talvez não tenha a funcionalidade do Cruise Control? Porque todo o resto está funcionando, pelo que posso dizer.
Você pode tirar uma foto dos números da sua ECU? Posso compará-lo com o meu para ver se é diferente.
Oof, okay, to better help you I need to know some things.
1. Are the switches and the harness all aftermarket? The wires do not look factory.
2. Did you do any wiring? Or did you just install the harness the way it was?
I have a spare cruise control switch so when I get home I'll tear it open and tell you which wires are for what. We can move forward form there.
Edit:
Looks like the switch is a bit different so can't help there.
But I already found the pinout, and all the wires on this connector look okay and in the right slots.
Hi bro @FlowMix , currently I had civic 8th gen with 2.0 engine (not sure ecu is compatible for this DIY), what's engine of your civic? and I manage to get OEM cruise control switch similar with photo you've share, could you share the function of each cable of this cruise control switch?
can someone help with how to make the illumination work for the steering audio control? i have it installed now and the steering audio control is working but the illumination isnt. do i need to add wires to this connector? this is the one behind the steering column
61 - 71 of 71 Posts
