81 - 93 of 93 Posts
Well I made a magical discovery today....if you happen to have the wiring harness out of the car....look at the wires....my LX harness has the name of each wire printed on the side of each wire.
Edit....False lol I thought about it and my Crutchfield Harness was what had the wire names on it :haybunny:
I have a 2006 civic ex coupe with premium audio (Canadian model) food for thought guys....
I had a aftermarket avic 6000nex installed with a steering whell pac rci module everything worked great 2 years later I had a abs light cone on NO BIG DEAL took it to the dealership they where NOT able to communicate with modules on the kline, as it turns out 6.5 hours later @ 100.00 a hr the signal used for the sterrring wheel module was pin 7 @ the dlc YUP kline was short to ground, I'm writting this for those whom might have had similar issues or those who want to tinker with there Car, I've spent over 600.00 for the dealership to find the problem so it's money you guys don't have to spend
Sent from my SM-T560NU using Tapatalk
good find pumpdog question for ya or anyone, i have a 06 Ex w/o navi but with the crap stock amp w/ 7skrs /8'' sub and im going aftermarket AVIC-N3
aftermarket subs spkrs etc etc .... whats the best thing i should do ?
A) run new speaker wire from spkrs to amp and from amp to rca > AVIC-N3
B) using the stock wiring ? how what do i do? i dont want LOC since i already got aftermarked better upgrade stuff......
forget stock sh!T:pat: :eek:hnoes: and spent that same amount of money on good aftermarket stuff:laughing: :thumb: heck even i know where to get better deals then CC/bb hit me up
for the metra aswc-1 red accessory wire do i connect it to the purple or the white? and if its the white which # white is it?
Radio Harness
+12V DC Constant White
Switchedd Accessory Violet
on the axxess pic it says 12v accessory which is purple but on the list of wires the 12v is white?
help pleassse asap
242027
242028
Radio Harness
help pleassse asap
View attachment 242027 View attachment 242028
The violet is switched power so it only comes on when the key is on. That is the best option unless want to possibly wake up with a dead battery one morning.
Yes I know old post, especially the OP... lots of good information here, BUT
Long time civic owner, short time on this board.. researching replacing speakers in my Civic '08 EX Coupe Premium Sound system, and diagnosing an issue of no sound in the rear deck and sub...
sinplybao .... posted a response indicating a definitive wire diagram was attached, With a couple links to the diagrams..
Apparently the link has been changed/broken over time, I know its a very old post but if you are like me the data is still around.
Could you update/repost the links I sure could use them, there is a lot of confusing information floating around the interweb of mis-information.
If someone else has this downloaded and saved away, I sure could use them.
Also trying to find where/how wiring runs from factory Amp to Front Door & Tweeters.
'08 Civic EX Coupe with Premium Sound..
There is no Coil/Inductor on the mid/door speaker and no Capacitor on the Tweeter.
Where is the crossover located, the amp only has outputs for Front Left & Front Right, the door speakers have only 2 wires each, and the colors are different at the Tweeter's than the door speaker... Gotta be split somewhere and logic says there has to be, should be, a crossover network somewhere.
Edit-- The Amp actually does have separate outputs for L/R Door & L/R Tweeter, just can't find where in the wire-harness the tweeter wires run.
Have all these diagrams disappeared? I don't see any diagrams or pictures, etc. attached anywhere in this thread...
2006 Honda Civic Audio Wiring Diagram
:Radio Harness
Ground Black
Power Antenna Gray
Remote Turn On Light Blue
Illumintation Red/Black or Gray
Left Front + Light Green
Left Front - Pink
Right Front + Gray
Right Front - Brown
Left Rear + Yellow
Left Rear - Brown
Right Rear + Blue
Right Rear - Orange
:Amplifier Outputs
Left Front Mid + Light Green
Left Front Mid - Pink
Right Front Mid + Gray
Right Front Mid - Brown
Left Rear Mid + Yellow
Left Rear Mid - Brown
Right Rear Mid + Blue
Right Rear Mid - Orange
Subwoofer 1 + Green
Subwoofer 1 - Red
:At Speakers
Left Front Tweeter + Red
Left Front Tweeter - Green
Right Front Tweeter + Pink
Right Front Tweeter - Blue
How I know between which is positive and negative on the rear back speakers.?
81 - 93 of 93 Posts
