301 - 320 of 406 Posts
thanks for the quick reply.. will be doing this over the weekend.. one more thing, i noticed that on my lx it doesn't have the wiper int ring.. i also wanted to replace it while I'm at it. do you think if i just replace it, will it work?
To upgrade to the EX/Si variable delay you would need a single wire ran from the fusebox/MICU unit to the new wiper switch.
when you buy the new controls, you will harvest the pins from the old cruise controls. you will need to pry them out.. it wasn't too easy btu it wasn't that hard either.
to clarify, you will need 4. 2 per harness. one of the harnesses is behind the radio and the other is behind the steering wheel under the little cover.
^^ I can imagine.. I can't wait!!!
However, I just looked at the pics again and I need to clarify my earlier post.
When I was talking about the 2 pins, I was actually referring to the wiring harness (as the OP called it) that is in pic 17 (3rd Last pic). Where can I get that?
