61 - 80 of 561 Posts
Discussion starter · #61 ·
With mine, I can fill up and when I used to get about 40miles off the first bar, I now get about 30, and after the first bar is gone the rest just fly away. One thing I notcied though was that when it showed I had about 2 bars left and filled all the way up, It only filled 9.5gals where it used to fill about 10-10.5
Exact same with me.
Can I clear my CEL for the newly installed race header with cat delete using flashpro? If so how?
You can clear it but it will come back unless you install an O2 sensor simulator (defouler) or disable the secondary O2 sensor.
Closed loop parameters
Open FlashPro -> Load your calibration -> Click calibration tab -> Closed Loop -> Uncheck "Secondary Oxygen Sensor Enabled"
Discussion starter · #67 ·
Thanks will this interfere with normal engine operations? I'm using a maf base calibration.
Edit: duh it's not pluged in anyways lol sorry
Disabling the 2nd O2 will not affect engine performance. The Primary is only for engine performance, the 2nd is strictly for emissions measurement purposes.
Here is my question for you flashpro buffs. I bought a stage 2 ct supercharger from a guy i know without the reflash, which was not a problem because i intended to get flashpro anyhow. So what i was wondering was basically how "in depth" is flashpro? does it change its settings for pulley sizes and whatnot? thanks in advance
Now if this isn't a noob question - (*As I go hide under a chair*)
Will be going CT-E Stage 2 (3.3") w/ all the bolt ons (i/h/hfc/e), is there a tune on flashpro that I can use to safely drive from point A, where I'll be installing it all, to point B, where I'll be having it tuned? If so, is there a different base map that is recommended as a starting point to use at the dyno?
map
i believe you still use the stage 2 3.15 base map. i dont think they have a 3.3 base map. when i was looking to upload. i just used the 3.15 base map
Thanks a heap. Never used the kind of tools we have today for tuning, so this is good info here.
