21 - 40 of 561 Posts
I've asked for additional clarification to that. I still don't quite understand which scenarios it will record a value. In any case, what does seem to be true, is if you have a value in that table, IT WONT CLEAR.
I noticed that I still have a litle DBW lag when I speedshift from first gear to second. All others gears are really quick with no lag. Did somebody noticed that? Can I correct that with my flashpro?
My map is: SRI K&N V2
Vtec 4700@8500
Thx
Step by Step manual driver install on Windows 7
1. click the start orb
2. right click on "Computer"
3. click "Manage"
4. click "Device Manager"
5. the FP should be listed with a yellow ? mark under "other devices", right click on the fp in device manager, click "update driver software"
6. click "Browse my computer for driver software"
7. click "Let me pick from a list of device drivers on my computer"
8. click "Have Disk"
9. Click "Browse"
10. in the Browse dialog, click "Computer" on the left part of the screen.
11. double click "C:\"
12. if you see "Program Files (x86)", double click that, if not double click "Program Files"
13. double click "Flash Pro".
14. double click "Drivers".
15. select "FlashPro.inf" and click open.
16. click ok.
17. select the flashpro driver and click next.
(let me know if I missed any steps and I'll update this post.)
Hello all-
Just about to install FlashPro into my Si.
Vibrant header w/ HFC
Vibrant catback
K&N V2 intake
P2R throttle body spacer
Hondata manifold gasket
I was bummed that Vibrant options were not included in the filter section of FlashPro. Also, limited option for catback exhausts. The best option I could find was...
Civic-Si-RRB-KNSRI-RH = FG2/FA5, K&N V2 SRI, race header, highlfow cat, stock catback.
Why would Hondata include a stock catback with so many bolt ons? Do you guys have any suggestions for a default calibration that would work with my setup? I will have the car tuned in January but would like to install today with a default setting. Thanks!
The calibration you've picked out will be a great starting point. Don't stress it. Read up on Hondata's help file on how to properly tune your fuel and then follow their instructions.
The reason for including the stock catback as part of the calibration is due to the fact that the stock exhaust on our cars is very good. Many of the exhausts on the market actually flow worse than the stock exhaust (Vibrant's is one of the exceptions). The majority of people with catbacks aren't really gaining any power by switching from stock.
Discussion starter · #30 ·
Well since it is not accurate, then the A1 B1 codes won't be accurate either because it is all based off of the same "meter". However, the only things the A1 and B1 codes tell you are when it is time to change different fluids (coolant, transmission, etc) so you should be doing that regardless of what the meter tells you.
The purpose of the meter is to help people who are not so car savvy keep up with maintenance.
Just got my flashpro. Downloaded my INJEN + raceheader map everything is working fine . I just have a question ?
1) Do I have to bring my labtop to the car every time i want a different map?
no, just plug the FP into your lappy and upload whatever cal you want through the FlashPro dialog. Then take the FP out to the car and hit the program button. It's similar to the AP in that regard.
Uploading from the FlashPro to the ECU
To upload a calibration which has been previously stored on the FlashPro:
1. Plug the FlashPro into the diagnostic connector and switch on the vehicle ignition.
• Primary calibration - press the Program button for at least one second.
• Secondary calibration - holding the Datalog button down, press the Program button for at least one second, releasing the Program button before the Datalog button.
I'm trying to do a street tune on my fuel trim...
In the Help contents it show you how to tune the low cam by locking each cam angle and make runs from 1000-6000rpm at different loads. While this is great if I lived in a rural area, but a bit tricky in my neck of the woods. Besides there are no instruction for high cam tuning. I would assume that the same process is applicable, except to run at 3000-8500rpm.
Anyway to my question... Is it acceptable to just run a long datalog, say, on my way to work and try to vary rpm and load as much as possible? Since the cam angles are already set, wouldn't this give a decent real world data? I know that the difficult part is to get all the applicable load and rpm columns filled with lambda data on just street driving. But with enough data logging I was thinking it would be possible to cover most fuel trims that would coincide with my driving style.
Any input would be most appreciated...
does anybody have any experience with the push button start feature with flashpro? I am working on a new project to use a smart key interface for keyless engine start. I tried searching but i did not find many results. any input would be greatly appreciated
Discussion starter · #37 ·
If i roll back to stock again, is that mean the meter is start counting again? or will it back to normal?
Sorry, I was away for a while there from the threads, but to answer your question, yes, stock calibration MAF based with return the meter counting like normal again.
Discussion starter · #38 ·
It sounds like a good idea actually to have a long datalog. However, you run into the issue of being "lost" in the middle of the datalog in knowing where and how you were driving at that particular time. My recommendation is to record many different smaller datalogs, each datalog with a different driving style (different load for example), and then you can get your info that way.
As far as how to tune the high cams, I vaguely remember the help docs mentioning to lock the high cams in a similar manner as the low cams (basically lowering the hell out of the vtec crosspoint) but I can't remember as to how much.
Can others fill in on this one?
Discussion starter · #39 ·
I don't think flashpro has anything to do with button start feature as flashpro is simply a reprogrammer for the ECU. Even without flashpro, the push button start conversion doesn't really matter to the ecu as much as other hardware.
Anyone can correct me if I'm wrong.
is there a way to upload the tune on the car onto the flashpro and then to the computer? when i got my car tuned with FP, it wasnt with my laptop. and i had to reinstall the FP onto laptop so i hope there is a way to get that tune again
