This is driving me insane. But I really don’t wanna spend over a hundred bucks to replace. Anyone found a cheap fix to make this look less stupid?
Hi, for the side windows I installed this aftermarket set about a year ago and they’re working just fine.Thanks, I need to get some of that.
On a similar note, I also need the weather strips for side windows on 2008 4-door EX. $50 each OEM, OUCH! Has anyone tried the aftermarket ones for $50 for the whole set?
Can you provide me the link for india??cheap fix
Hello.
Ha ha. No you don't need to make it stay that way and you don't need to pay $100 for the trim.
What I did was go to home depot > go to house door section > buy some squishy rubber trim > I bought 1/4" thick, but in hindsight, if they have a little thicker it is better. I can't remember the cost - probably $3-7 for a roll, which is enough for both sides plus extra.
The 1/4" rubber trim width fits well in most of the slot, except the ends where you have to taper it with a scissors, and the middle where it is a little loose (hence recommending buy little thicker). Don't need to worry about making it look neat when you cut - you won't see the sloppy cut because you're squishing the rubber in there and can't see it when its done.
I didn't bother adding extra adhesive... the rubber stayed in place and did not move around for 3 years (until the windshield repair man pulled one side out and threw it away). I have to reinstall one side.
good luck.
adesh
