1000cc injectors??
11K views 19 replies 8 participants last post by  ATL Si
#1 ·
okay i've been doing a ton of searching and reading and i'm seeing a lot of different input. I'm working on getting a part list together for my build.
it will consist of:
ct stage 2 supercharger 3.15 pulley
injen sri with battery relocated to trunk
skunk2 megapower headers
skunk2 76mm catback
a lot of people are talking about it would be good to upgrade the fuel pump and get better injectors than what comptech gives you.
some people say 1000cc and walbro 255 is the way to go, some say it causes issues with warm starts. I was hoping to get by with the right injectors and walbro and avoid crushing my fpr. I was also seeing that the ID 725cc injectors were good too but idk.
someone with some knowledge please help!!
#7 ·
The DW65c is the Deatschwerks 65c, it flows more than the Walbro and is a better pump. I would normally recommend the DW300 (I personally run 3of these pumps), but you don't need the 300 flow with the charger and the 65c is easier to install than either the Walbro or the dw300. I like the DW pumps so much I'm working with Deatsch on carrying them in my store.
#11 ·
I have ID 1000cc injectors and a Walbro 255 (and crushed fpr). It is a loud pump, I'm on my second one because the first one quit on me for no reason. I've heard good things about the DW65c, so I'd give that a try. As for warm starts, the car just cranks a lot more before it starts...maybe two or three times as much. Never had a problem with it not starting though. If you can get away with 725cc I'd go with that. Good luck!
