Edit - at first glance, I read the side of the cap incorrectly as 150 uf instead of 1.5 uf - sorry for the mixup.
In a 1st order butterworth setup at 4 ohms, a single 1.5 uf cap would yield a 6 Db/octave rolloff at approx. 25,000 hz (which is completely useless, and above the range of both normal human hearing and the CD recording process). At 8 ohms, the same cap would yield a 6 Db/octave rolloff at approx. 12,500 hz. Which isn't very practical either, but in theory would allow for some audible sound out of the tweeters.
The only thing I could perceive them doing is using a voice coil (or resistor) to create a 16 ohm load - in which case the 1.5 uf cap would yield a more reasonable 6 Db/octave rolloff at approx. 6,250 Hz. This would lower tweeter output relative to the door speakers, which would make sense considering the factory location firing into the windshield glass... a band-aid to reduce harshness.
I'm curious as to the static impedance of the factory tweeter. You may find yourself needing to use a lot of cut up top if the above is indeed the case.
Hans
