Rear Defroster relay location?
6.7K views 2 replies 2 participants last post by  less
#1 ·
Hi all,
For some reason, my rear defroster is only seeing 10 volts and isn't functioning at all from what I can tell. The only reason I can think of is that the relay or fuse aren't operating correctly or aren't seated well, or that there's a wiring issue (and I've inspected the runs and see no visible damage). I've found the fuse fine, and swapping it didn't make a difference. Does anyone know where the relay is located?
I'm also open to other ideas on what might be wrong with it. Thank you in advance.
Jim aka Less
