R18 exhaust questions?
9.6K views 25 replies 13 participants last post by  hugo2351
#1 ·
what does it do if you put a 2.5 inch exhaust with a 2.25 inch axle back at the end of it?...any goods? or any bad???? thanks
#6 · (Edited)
Yes, the extra .25 inches would make a significant difference in sound, backpressure, and powerband. At least it would if the r18 had any balls...I hate that our cars don't even have enough umph to discard of a 20 year old civic equivalent... :cry:
Actually answering your question, though...having a smaller axleback than the rest of the piping will increase backpressure that was initially reduced by changing the stock midpipe to a larger diameter, thus potentially counteracting the purpose of increasing the diameter of the catback...
Drop shipped to you from my GS2
#10 ·
Now don't let that discourage you from upgrading your exhaust. You may not get a lot of power out of an aftermarket exhaust, but you will get a unique sound. If it's sound you want, go for it, or better yet, wait till you can afford a full catback from greddy, tanabe, or another reputable exhaust manufacturer.
#19 ·
Here is why increasing the exhaust diameter really helps. The formula for area of a circle is pi * r^2.
2.25" dia = 4 sq in
2.50" dia = 4.9 sq in (24% increase)
3.00" dia = 7 sq in (78% increase from 2.25")
By increasing the area, it reduces the back pressure, but also slows (and therefore cooling) the exhaust gases. Most stock systems reduce the total diameter from the engine to the tail pipe. Fluid dynamics says that the most efficient way to move fluids (and air) is laminar flow, I'm guessing that is the reason factory exhausts do this.
But, the track and history proves that bigger exhaust in the end is really better.
