R18 engine can run without thermostat?
5.1K views 5 replies 6 participants last post by  netfixer
#1 ·
Hi all,
I live in very hot climate, engine run 188f degree, which is i think very hot & i getting very bad FC, anyone bros out there run there R18 engine without thermostat or any bros out there lives in very cold climate with R18 engine & experience better FC when the engine is colder? Thanks in advance...
#2 ·
Not sure why you think 188f Engine coolant temp is hot.... it's absolutely perfect. Engines should run between 180-210f at all times for peak efficiency. Now, you can run them cooler if you NEED to if it's heavily built. I believe you would need to locate a thermostat that opens sooner, and is designed to run at your goal temperature.
