Mounting aftermarket tweeters in stock tweeter location?
8.2K views 13 replies 9 participants last post by  kgee
#1 · (Edited)
How do i do this? I have an LX sedan so it didnt come with tweeters. I noticed on the grill it has holes for the stock tweeter to clip into. I was gonna hot glue it in but the manufacturer of the glue says it melts at 170... it gets that hot in the summer time. So i think i'm gonna zip tie the holes so the tweeter will rest on the zip tie, firmly in it's location. YAH GOOD?
#7 · (Edited)
Will i beable to remove it later if i have to? lol
I just drilled 2 more holes so there would be holes directly across the holes that are already there and tied the tweeter in using plastic string in an "X" shape. I dont know how hot tweeters get but hopefully it wont melt the plastic.
#10 ·
Count down to criticisms of stock location for tweets. T minus and counting.. 7, 6, 5, .....
Couple things about the stock grills.. If you want to experiment, they're super cheap over the parts counter for an extra set.
I'd like to see someone do a top-mount attached to the grill angled forward to see how it turns out, instead of just radiating off the windshield. Some better component tweeters will have angled top-mounts for that. Not getting into wiring and crossovers or processing etc... If you're going with active tweets, one of my favorite ideas for that spot are SEAS neo's with the LPG angled mounts from madisound. Do some RS180-4 daytons or maybe mach-5 MLI-65's in the door, good active crossover... yeeehaw!
... sorry.. Haven't been lurking around here much lately. :) Good coffee this morning.
#11 ·
I took the stock grills out of the car, of course, drilled pilot holes in each of the surrounding brackets. I used rockford fosgate P1P tweeters, which have a flange on the outside of them, so I dremeled that off to fit snugly inside those brackets. Then I took epoxy and stuffed it in the spaces between the brackets and the tweeter, making sure that the epoxy was stuffed into those holes as well. That will secure that if the epoxy doesn't stick to either the bracket or the tweeter, that it will stay in place by the holes. That's just what I did. I don't have them hooked up at the moment, because after i got them in and got my amp hooked up I had an issue with a channel and I had to send the amp in for repairs. But off of the radio it sounds pretty good. However, I do like the idea of changing them and where they are. Maybe fiberglass some pods to face forward that are connected to the factory grills somehow for removal purposes. That was a good idea, bsbabcock.
