Key FOB, battery voltage level
6.2K views 4 replies 4 participants last post by  Beckerson1
#1 ·
Like many of us with key FOB's the battery needs replacing from time to time due to usage. I am presently experiencing issues with having to be up next to the vehicle for the lock to unlock and even then it may require a couple of presses. I took the battery out and the voltage measures about 2.5 volts. At what point is loss of voltage considered to be enough to replace battery? For those who don't have a volt meter I would encourage you to get one. Easy to use and helpful in trouble shooting batteries, including the car battery. I've noticed the last couple of weeks a slight delay in the engine turning over (if you're not the daily driver you probably wouldn't notice it) and I still have the factory battery that is coming up on three years (still under warranty). I went out this morning and checked it since it's been sitting out overnight in the cooler temperature and it still shows 12.5 volts.
#3 ·
Replacement battery seems to have done the trick though i'd still like to know as a matter of interest how much drop off in the 3 volt battery is required to diminish function (no red light with press of the button).
#4 ·
go to honda and have them put there battery in its smooth on the one side the other have grooves on them we had this problem with my wifes o9 accord 2 new batt n still had to press the botton alot to get it to open also the bateery gets a lil bit of some grease res-dew on it that dont help either
#5 ·
I notice the same thing... as of lately mine has been getting drastically worse. I could lock it up to 20' away (couple presses) and now its down to about 5-10 with a couple presses on a good day.
But all that will change by Dec.
Getting my Security system before I head up to main campus. (Mainly because I will live up there and its common beyond belief for things to get stolen/broken into.)
