How to find Honda's TSBs and SNAs.
12K views 11 replies 8 participants last post by  nolicense526
#1 ·
After a bit of playing around I've found the URL pattern to get all Technical Service Bulletins (TSB) and ServiceNews Articles (SNA) from Honda. If you're looking for a particular TSB or SNA and don't have the TSB number or SNA publication date you'll need to just look for them sequentially or get the TSB number or SNA publication date from one of the other posts here.
To find a TSB:
The URL pattern is:
http://www.in.honda.com/Rjanisis/pubs/SB/AYY-XXX.PDF
Where YY is the two-digit year and XXX is the 3 digit sequence number.
For example, the Service Bulletin for "Navigation System DVD Information and Inspection" (bulletin number 05-032) can be found here:
http://www.in.honda.com/Rjanisis/pubs/SB/A05-032.PDF
NOTE: Change the "A" to "B" and you'll find the TSBs for Acuras!
To find a SNA:
The URL pattern is:
http://www.in.honda.com/Rjanisis/pubs/SN/AYYMM00.PDF
Where YYMM is the two-digit year and two-digit month of the article. They come out once a month.
For example, to get the latest, March 2008 ServiceNews Article the URL would be:
http://www.in.honda.com/Rjanisis/pubs/SN/A080300.PDF
And, you can change the "A" to "B" to get the Acura ServiceNews Articles too!
Have fun!
Larry.
#4 ·
I think the 2 dead links you're taking about are the URL pattern ones. Those were not meant to be valid URLs. The examples should be valid and work. The pattern ones are there to give the general pattern and the user would replace the "YYMM" with the year and month or replace the "YY-XXX" with the year and sequence number for a service bulletin.
As for the title, whoops :redface:! Sorry about that. I mostly frequent the HondaPilot.org forum since I drive a Pilot. My wife is the one who drives our '06 Civic. I posted this information there first and then did a cut-and-paste to this forum
Thanks!
Larry.
#7 ·
The link in my signature is a compilation of every Honda Service News Bulletin from 2003-2008 (and ongoing).
It's already stickied. As for the TSB thing, good find. I figured it'd be a similar process.
And as for the Honda Service News Bulletin, my link has notes for every Civic related issue detailed in a given issue of the bulletin.
#8 ·
Here is what I have come up with for all of the TSB’s for the 8th gen civics. I cannot grantee that this is all of them but it’s a good start. I started at in 05 and went to 08 as of last week sometime. There may be newer ones. I was able to create a program that would generate the urls for me then I was able to paste them into a downloading app. This is how I was able to get all TBS from 05 to 08, using the formula listed above.
Using the formula listed above add the AXX-XXX.pdf to the end to get the appropriate TSB you are wanting to look at.
Please let me know if there are any errors. I will be glad to edit the post.
A05-032.pdf ALL- Navigation system information and inspection- informational
A05-041.pdf ’06-all - Civic audio Unit Diagnosis -informational
A05-042.pdf – ‘06 Civic Sedan, Coupe: PDI and New Model Information
A05-044.pdf – ’06-’08 Civic with Navi and Hybrid with Navi- PDI of the DVD Navigation System With Voice Recognition
A05-047.pdf ’06 all- Paint Codes
A05-055.pdf - 2006 Civic Hybrid: PDI and New Model Information
A05-061.pdf - Safety Recall: 2006 Civic Accelerator Pedal Inspection
A05-066.pdf – ’01-’06 ALL- Universal Front Subframe Removal Adapter
A06-001.pdf – ALL - Audio, Navigation, and RES Unit In-Warranty Exchange, and Audio and DVD Player Out-of-Warranty Repair
A06-002.pdf - ’06 2-door Safety Recall: ODS Unit Does Not Suppress Airbag Deployment, and DTC 82-12 or 83-22 Is Stored
A06-006.pdf – ’06 2-door EX- Rear Shelf Rattles When Playing the Audio System
A06-007.pdf – ’06 2 and 4 door. SRS Indicator Stays On, and DTC 86-16 Is Stored
A06-008.pdf- ’06 - Immobilizer-Keyless Control Unit or ECM/PCM Cannot Be Rewritten
A06-011.pdf- ’06-’08 Civic all - Immobilizer System (Type 6)
A06-013.pdf- ’06 Hybrid- Product Update: Gauge Control Module Displays Erratic Average Fuel
Mileage
A06-014.pdf- ’06-07 4-door and hybrid - Front Door Glass Comes Out of the Channel
A06-020.pdf- ’06 4 and 2 door - Engine Oil Leaks and Power Steering Fluid Leak
A06-028.pdf- ’06 GX 2006 Civic GX: PDI and New Model Information
A06-031.pdf – ’06 See Affected - Front Seat Clicks When Sliding or Does Not Slide
A06-034.pdf – ‘06 See Affected- Keyless Remote Intermittently Does Not Unlock the Passengers’ Doors
A06-036.pdf – ’06 See Affected- Immobilizer Indicator Is Blinking, Engine Won’t Start
A06-048.pdf – ’06 ALL- MIL Comes On With DTC P0116
A06-052.pdf – ’06 SI- Engine RPM Does Not Immediately Drop When Shifting Gears, Vehicle
Surges When Driving in 1st Gear
A06-059.pdf – ’06 See Affected- Buzzing From the Engine at Low RPM
A06-060.pdf – ’06 See Affected- Rattle From Right-Front of Vehicle When Driving Over Bumps
A06-068.pdf – ALL - Vehicle Pulling or Drifting
A06-069.pdf – ’06 2-door- Safety Recall: Rear Window or Quarter Glass Rattle or Looseness
A06-070.pdf – ’06 2 door and SI- Product Update: SRS Indicator Stays On, and DTC 86-25 Is Stored
A06-071.pdf – ’07 Sedan and coupe- PDI info
A06-072.pdf – ’08 ALL- TPMS Sensor Tool Usage
A06-075.pdf – ’07 hybrid all- PDI info
A06-076.pdf – ’07 GA ALL- PDI info
A06-080.pdf – ’06 4-door See Affected- Roof Molding Is Stained
A06-082.pdf – ALL- Tubeless Tire Repair Information
A06-086.pdf – ’06 and ’07 See Affected- MIL Comes On With DTC P0455
A06-089.pdf – ’07 ALL- Pint codes
A07-004.pdf – ’06 & ’07 See Affected- Front Seat Cushion Cover Is Loose
A07-008.pdf – ALL- Clarification of Honda Unibody Repair Policy
A07-009.pdf – ’06 hybrid all- Safety Recall: DC-DC Converter Output Cable Is Pinched by IPU Lid
A07-012.pdf – ALL- Music Link (For iPod) General Information and Symptom Troubleshooting
A07-030.pdf – ALL with A/C- A/C Leak Detection
A07-041.pdf – ’06 hybrid ALL- Occasional High Engine RPM During Deceleration
A07-043.pdf – ’06 4-door- Popping Noise While Turning
A07-044.pdf – ’08 ALL- Paint Codes
A07-048.pdf – ’08 sedan and coupe- PDI info
A07-066.pdf – ’06 & ’07 See Affected- Safety Recall: Rear ABS Wheel Speed Sensor and O-Ring Inspection
A07-058.pdf - 2008 Civic GX: PDI and New Model Information
A07-061.pdf – ’06 & ’07 See Affected - Safety Recall: Brake Pedal Position Switch May Fail
A07-062.pdf – ’06 & ’07 See Affected- Poor A/C Performance During Acceleration
A07-071.pdf – ’06 & ’07 See Affected- Windshield Wipers Intermittently Do Not Park or Turn Off
A07-077.pdf – ’06 & ’07 All with AT- Brake Pedal Feels Hard in the Mornings or in Cold Weather
A07-078.pdf – ’06 & ’07 coupe and SI 2 and 4 door- Pop or Clunk From the Front Suspension While Driving Over a Bump After Turning
A07-081.pdf – ’98 thru ’07 GX- Safety Recall: Fuel Tank Thermal Insulator
A07-085.pdf – ALL - ATF Leak Detection
A08-001.pdf – ALL except SI- Uneven or Rapid Rear Tire Wear
A08-003.pdf – ALL- Update the PCM When Replacing the Transmission
A08-009.pdf – ’08 hybrid PDI info
A08-013.pdf – ’07 & ’08 See Affected- MIL Comes On With DTC P0456
A08-014.pdf – ’07 & ’08 hybrid - Harsh Transmission Engagement After Auto Idle Stop
A08-015.pdf – ’06 SI all - 2006 Civic Si: MIL Comes On With DTC P0420
A08-020.pdf – ’06 thru ’08 ALL - Transmission Grinds When Shifting Into 3rd Gear, Pops Out of 3rd Gear, or Is Hard to Shift Into 3rd Gear
