DIY- Front License Plate Flip W/ Pics
311K views 455 replies 283 participants last post by  abquid
#1 · (Edited)
First Things first. Tools required--
1) Something to cut the plastic (I used a Dremel with a cutting bit)
2) Phillips Screwdriver to remove the lisence plate and bracket
Difficulty level- 1/5. Cutting is required.
Alright so you have to remove the liscence plate to get at the two bolts behind holding the bracket on. Then remove the Two bolts holding on the bracket and place the lisence plate w/ screws off to the side.
Your going to want to cut off the plastic "Humps" to make it look like the picture below. This is where the Dremel will come in handy. You can use tinsnips if your *really* good with them... but the dremel was just that much easier. Be careful to not cut it down too much and hit that hole where the screw goes through, as thats where the bracket is connected to the grille.
Flip it around and re-mount it on the grill.
Heres how it should sit from the side.
Success- Thumbs up!
Looks like this afterwards--
Good Luck and Thanks for looking
-Shawno
#448 ·
For the sedan all you have to do is take off the oem holder, flip it, move it down one "notch" on the bumper, and zip tie it to the black plastic through the holes where the original small bolts went. I didn't want mine to slide left and right and I also wanted it offset so I used 2 zip ties in the left (looking toward the bumper) hole and tied one to the left of the black upright plastic and one to the right so it doesn't slide. If fishing the zip ties through is difficult, bend them into a "U" shape. And I have to say, it looks much cleaner now with the plate lower although I would rather leave it off.
