Correction!! LOUD Metal sound from Wheel Wells
8.8K views 34 replies 8 participants last post by  Jui$e
#1 ·
Hey guys, hope everyone is well.
I have a real loud metal on metal sound coming from somewhere in my front wheel wells. The car is driving perfectly fine. When I roll or drive, the sound gets intermittenly louder. It sounds like there is metal dragging from my car. Please some input!
ps. there is def no metal dragging....it's also 15 degrees outside.
#16 ·
well another thing is do u hear it ONLY when u brake? or if ur driving. a caliper seized but not too hard u may not notice a pull. When my rear one seized on my teg i noticed no pulls. BUt at a stop something STANK like a mofo.
like clutch burn with brake fluid mixed in but something i have never smelled before. so i walked around and smelled it around my rear driver wheel then i went to touch the lugs and they were on FIRE compared to the other lugs on the other wheels thats how i found out.
the wear indicator should only squeal when u get on the brake not at ALL times unless the caliper is partially seized. ANother thing it may be is wheel bearing issue (that jar of change sound) is most similar to a wheel bearing going out.
One test is to jack it up and wiggle the wheel. If there is play in it then u prob have a bad wheel bearing
#18 ·
hmm yeah, i know exactly what you are talking about. I had a seized caliper on my Celica. This is def something completely different. I feel that it doesnt have to do with the brakes. The squeel is when i drive, not necissarily when I brake. It's def more similar to the "jar of change sound". I was thinking maybe something to do with the struts...no clue really.
#30 · (Edited)
Having the same problem as the OP. I cant figure it out. First thought it was the passenger side axle but we changed it and put a brand new one in and Im still having the Loud sound. Its pretty much anytime I hit the gas and gets louder the more gas I give it. I started noticing the sound when I was coming home one night and some **** cut me off and slammed on his brakes in front of me. I slammed on my brakes pretty hard and the car jerked to one side. Ever since than im hearing that sound
OP - what did yours turn out to be ?
