08 civic si rpm’s go up while shifting
2K views 3 replies 3 participants last post by  Bdubz5
#1 ·
08 civic si cleaned throttle body now get p0505 code rpm’s are up and down in neutral and when I push clutch in while coasting new throttle body new oem intake boot checked for vaccum leaks please need help and yes did throttle pedal relearn
#4 ·
Anytime you mess with the throttle body, clean it take it off etc your moving idle with be screwed up. I took mine off to fix something and put it back on and when driving and push the clutch in coming to a stop it would go from 1600 rpms down to 900 back up to 1600 and back down to 900 over and over again. I just kept driving the car so the car could learn the fuel trims and the issue went away which takes about a half tank to fuel tank of gas. A obd2 scanner tool should have a idle relearn on it otherwise honda charges 100$ to do it.
