Old 09-20-2007, 09:18 PM   #1 (permalink)
60103's Avatar
Ken
DIY Parking Brake Adjustment
Parking Brake Inspection and Adjustment
Inspection
1. Pull the parking brake lever (A) with 196 N (20 kgf, 44 lbs.) of force to fully apply the parking brake. The parking brake lever should be locked within the specified number of clicks.
2. If the number of lever clicks is excessive, adjust the parking brake.
Adjustment - Rear Disc Brake Type
1. Remove the front console panel.
2. Release the parking brake lever fully.
3. Loosen the parking brake adjusting nut (A).
4. Raise the rear of the vehicle, and support it with safety stands in the proper locations.
5. Remove the rear wheels.
6. Make sure the parking brake lever (A) on the rear brake caliper contacts the stop pin (B). NOTE: The parking brake lever will only contact the stop pin when the parking brake adjusting nut is loosened.
7. Install the rear wheels.
8. Pull the parking brake lever 1 click.
9. Tighten the parking brake adjusting nut until the parking brakes drag slightly when the rear wheels are turned.
10. Release the parking brake lever fully, and check that the parking brakes do not drag when the rear wheels are turned. Readjust if necessary.
11. Make sure the parking brakes are fully applied when the parking brake lever is pulled all the way (8 to 10 clicks).
12. Install the front console panel.
Adjustment - Rear Drum Brake Type
4. Press the brake pedal several times to set the self-adjusting brake before adjusting the parking brake.
5. Pull the parking brake lever 1 click.
6. Tighten the parking brake adjusting nut until the parking brakes drag slightly when the rear wheels are turned.
7. Release the parking brake lever fully, and check that the parking brakes do not drag when the rear wheels are turned. Readjust if necessary.
8. Make sure the parking brakes are fully applied when the parking brake lever is pulled all the way (8 to 10 clicks).
9. Install the front console panel.
60103 is offline
Old 09-20-2007, 09:22 PM   #2 (permalink)
shutter13's Avatar
very nice DIY... will come in handy for many! +repped
shutter13 is offline
Old 09-25-2007, 06:39 AM   #3 (permalink)
Tastycakes's Avatar
Cool, i might tighen mine up a bit, i always loved ass dragging around corners in my buddies old civic
Tastycakes is offline
Old 09-25-2007, 06:53 AM   #4 (permalink)
1stk20z3's Avatar
Casey
yea ass sliding in the new civics is a little difficult.the new civics dont lock up very well huh.
1stk20z3 is offline
Old 09-25-2007, 03:42 PM   #5 (permalink)
Tastycakes's Avatar
Yea lol, its almost impossible to lock em up in the rain.
DIY Front Brake Pads 60103 Suspension 0 09-20-2007 08:58 PM
Accidently driving Civic EX with parking brake on jyong11363 Suspension and Brakes 12 06-01-2007 08:41 PM
Parking without parking brake (AT) amirh Mechanical Problems & Technical Chat 4 12-20-2006 11:12 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 3 12-07-2006 01:59 AM
Anyone with parking brake problems? Silver06 Garage 7 12-16-2005 01:18 AM
