81 - 100 of 111 Posts
Well let's see.
Year: 2008
Model: LX Sedan (KK spec not KA (US) spec if anyone is interested in that)
Miles (as of 09/03/2018): 43,240 miles
typical MPG: Honestly don't know, don't even know how to check this
Oil: Unknown, Oil has been recently changed by my Honda dealer
filters: OEM only
Issues:
- Few rust spots
- All weather-strips sticky
- Couple parts are rusted
- Wheels out of alignment
- Wheels out of balance
- Tires need changing
- Center console armrest broken
- Headliner drooping
- Couple lightbulb sockets broken (but somehow still work)
- Slight oil leak (if what i saw last time I was under the car was an oil leak)
- Handbrake does not lockup the wheels when pulled, only slowly slows down the car
- Very small power steering leak
- Weird noise at start up which lasts a few seconds while the engine is starting that happens once and a while which is really annoying
- That's about it for issues
Issues that have been resolved:
- I bought this car June 2017 from the original owner. Come late January my engine block cracked. Turns out my civic came with a faulty block from the factory as did many 06 - 09 civics and all civics of these years were given a 10 year warranty from purchase date specifically for the engine block in the event that it prematurely cracked (like mine did). I didn't find out about the warranty until late February and get this, my warranty on the engine block was expiring the next month because the original owner purchased this civic off the lot March 2008. I managed to get my civic to the dealer February 20th and they had my car until May 7th (I know, that's CRAZY). But they ended up changing the block with a new one that was sent out from Honda in the US and also fixed the oil leak that was a result of the engine block cracking.
- Brake pads were really close to their end so I replaced em
- The belt was getting old so I replaced it
- A/C condenser fan motor went bad which caused my compressor to click on and off every once and a while while the A/C was on (which I'm assuming it did that in order to try and get the fan motor spinning) which in return caused my RPM's to jitter every time the compressor clicked on and off. So I bought a new fan motor, replaced it and poof. My A/C condenser fan now works, my compressor doesn't click on and off anymore, and my RPM's are more or less always stable now and don't jitter.
- Garbage truck rear ended me. Hit the right corner of the vehicle and did substantial damage. The garbage truck company fixed the damage themselves and replaced the tail light though. Repairs were not professional by any means. For what it's worth though unless you closely inspect all the bodywork that was done you wouldn't mind the way it looks. Looks close enough to how it was before. I do plan on getting all of that redone by a professional though because I'm not happy with the bodywork they did.
- And that about sum's up all the issues I've had and currently have.
Okay so, a little about myself and my civic. I live in The Bahamas, and from the looks of it our dealer got a mix and match of KK spec and KA (US) spec 8th gen civics. And we have an ABUNDANCE of RHD FD civics on the island imported from Japan. My civic happens to be KK spec and isn't that different from US spec ones both exterior and interior wise. The exterior is exactly the same actually in terms of looks, interior is more or less the same (my civic is also LHD) but there are a few differences which I'll list below:
KK spec civic differences:
- Red hazard switch with white printed icon compared to dash colored hazard switch with red printed icon
- Blank rectangle indentation above hazard switch where passenger airbag indicator usually sits for US models
- Proper cigarette lighter socket with illuminated ring that comes with snap in lighter compared to accessory power outlet with AUX input beneath it
- A 2TR0 radio face compared to a 2AJ0 radio face
- An LX Badge on the trunk (All KK spec 8th gen civics came with trim badges on the trunk. And no, they weren't sourced from older model civics. The emblems were specifically made for 8th gen kk spec civics.)
- Didn't come with cruise controls so more than likely KK spec civics didn't come with cruise control. Haven't confirmed this with the dealer yet though. Maybe the feature is there but I just need to install the actual controls on the steering wheel. I definitely plan on digging into this in the future.
- Car doesn't beep when I press the lock button twice. Only the lights flash. So more than likely KK spec civics didn't come programmed to beep after clicking the lock button twice. Haven't confirmed this with the dealer yet either. I plan on digging into this in the future as well.
- And from what I can tell those are the only differences.
My country is kinda funny, we drive on the left, and RHD cars are better to use here because of this reason. But all dealerships on the Island sell LHD vehicles. The only reason we have so many RHD vehicles in the country is because locals are importing them from Japan. And we don't have any restrictions on vehicles. Once it runs, drives and passes inspection for licensing (which is extremely simple) it can be licensed in our country. The only restriction on vehicles we have is you can't bring in a car older than 10 years. That's it. So yeah. But that's it for my civic.
Year: 2006
Model: EX
Miles 170430
typical MPG: 33-34 MPG
Oil: Mobile1 Full Synthetic 5W-20
filters: OEM
Issues:
OEM Radio has developed a mind of its own. Switches between FM/AM/AUX on it own, then will just stop working all together often. Believe its due to the common "overheating" issue I've heard these radios have. Ready for a double din system.
Light metal rattle noise coming from underneath the car when moving from a stop often, and between 4K-5K RPM. Really sounded like the brake dust shield rubbing on the rotor, but after inspecting I don't believe that is the case. Probably a heat shield? Need to get under the car and start whacking stuff with a mallet.
One more small thing. The top cell on the fuel gauge will never light up after filling the tank, but I know is still functional as it lights up with the dash warning light check upon start up. Anyone else got this?
I've noticed when the gas pump automatically stops after filling up the tank that cell never lights up. But when you manually "top off" your tank the last cell lights up. It's not good to top off though. Our gas stations where I live have attendants, so everyone just let's them do it since it's their job. Problem with this though is these attendants top off your tank to round the price to the nearest dollar. I stop them from doing this when I can.
06 ex 80000 . wheel bearings rear. Besides the regular stuff. Brakes oil fluids filters all done by dealer. New tires at 78000. Inherited car from very old aunt . 101 when she passes drove till she was 98 . good grief.
2007 Ex 290,000 miles
Just hit 290,000 miles on my 2007 ex sedan single owner car. original motor and auto trans, no cracked block.
This is what I have done so far.
Recently replaced springs, sway bars, end links with new Si ones.
Replaced shocks with Koni oranges. Loving the ride so far.
Ball joints.
Replaced o2 sensors, injectors, plugs, and motor mounts.
Water pump, ac clutch and coil, hydraulic idler assembly, and belt.
Rotors and pads.
recently adjusted the valves and cleaned the throttle body.
This car feels like it has under 100k now. Hoping the new suspension will be better on my tires.
I bought a used 2010 EX from a local Subaru dealer a couple weeks ago. I just hit 110,500 miles yesterday! Hoping this car can get into the 200's without any major issues.
Fiji Blue
Year: 2006
Model: LX
Miles Got it 177,117 now with 188,XXX kms
MPG: Summer: 27-30 Winter: 26-28. 60% City 40% Highway
Oil: Oil changes done @4-5k intervals; Tried Motul Eco-lite 0w20 (Can't afford it lol) Mobile1: 0W-20 AFE (Current, have 3 Jugs), thinking of trying Toyota 0W20 soon (don't ask me why)
Filters: Honda AO2s :/, Mobil EP
Issues: Hmm Bad clear coat (May wrap roof gloss blk), Cracked engine block (Replaced), Warped FR rotor (Machined?) FR wheel bearing (Replaced), FL strut clunking (Will get Coils this summer), Brakes are kinda drummy (Will service them this summer), RR control arm has excessive camber (Can't afford to get adjustable ones), ATF+Coolant (Drained and filled), Spark plugs (Replaced), Power Steering (To do soon), Wiper inserts a bit chattery (New inserts in hand), Starter might be on it's way..sometimes takes 2 cracks once in a blue moon tho :/ , Belt (Replaced) Tensioner (Will be replaced when weather gets warmer)
I want to drive this till 300k just to give me some time to save. Next cars I want: Honda Civic Hatchback (10 Gen), Mazda 3 Sedan (3rd Gen)
Dream Cars: Nissan GTR R35, Honda S2K AP2, Civic Type R (10 Gen), Mercedes Benz A Class Hatchback (a45AMG?)
Year: 06 EX Couple Manual
Mileage: bought it at 50k in 2011, 105k now
Oil: 5W-20
MPG: I don't even know but it's pretty good lol
Issues: none so far
I have changed out the plugs, brake pads and rotors. That's it
Plan is to drive it until the clutch goes out.
Future purchase: Cement Toyota Tacoma TRD Offroad 4x4 DCSB
Year: 2006
Model: EX Sedan
Kilometers (Miles): 348,000km (217,500 miles)
Fuel Economy: Best 5.9L/100km (40mpg), all hwy. Mixed City/Hwy has been 7.2L/100km (32km)
Oil: 5W-20, or whatever the dealership puts in as standard.
filters: OEM only
Issues: Few rush spots and small leak of head gasket. No major issues overall.
We are the original owners. We took delivery in Nov 2005. We have had ZERO issues with this car over the course of its lifetime. We are extremely happy owners.
Fun fact, our VIN indicates we were the 438th model off the assembly line at the Scarborough plant in Ontario, Canada.
A lot has changed over the past 14 years, including being able to afford more expensive cars. I just can't bare the thought of selling this vehicle though. I still use it as my daily driver. It's just so inexpensive to run!
Other vehicles in "fleet": 2004 AP2 SK2, 2014 Odyssey Touring
Year: 2010
Trim: LX
Transmission: 5-spd auto
Mileage: 70,448 miles
Oil: 0W-20 (that’s what dealership puts in)
MPG: Not sure, but if I had to guess I’d say 23-24 city and 36-38 hwy. I put on mostly city miles and I’m a bit aggressive, so I don’t get as expected mpg.
Issues:
-Paint: clear coat is beginning to fade on back of roof
-Engine: needs new passengers side mount, new tensioner pulley
-Transmission: changed fluid and filter, about 3 us qts of Honda DW-1 fluid @ 67,896 miles. Never had any problems before and no problems now. Shifts like a dream!
-Drivetrain related issues: needs 2 new front cv axles, needs 4 new struts, whining noise but can’t figure out what it is
-A/C: smelly, thinking I need to clean the evaporator
Super Moderator
Discussion Starter #95
Just got a temporary steering wheel. I want to install the leather wrap I got it a while ago AND replace my audio buttons (worn). The gray trim around the wheel is getting worn too, pretty sure I'll be painting it.
still running like a champ!
Still looking good I think.
Love those headlights!
I am at 320k on my 06. It's my loaner vehicle to family and friends now... aannd its not so clean anymore. Still runs great! I was surprised, my last update on this thread was 2015! I have since went back to completely stock. Doesn't really get driven much anymore between my other vehicles. I honestly think that will be its downfall... if it sits, it will break :(
Super Moderator
Discussion Starter #98
LOL, thanks, those retros were not cheap. Anyway, I try to keep my rig as clean as possible and deterioration of parts is a concern. B/c my rig LIVES on the road, I fear when my days of driving a lot come to a close, my Civic will "come to a close" as well.
As it stands, drive on......................
2006 LX
5 speed
235,079 miles
Constantly 40 mpg on the hwy even today.
Original Owner
Garage kept most of it's life
Driven from Southern Georgia to Portland Oregon via Flagstaff AZ then back.
Multiple trips from PDX to Flag
at 198k was loosing radiator fluid every 2 weeks, finally got it in and had a cracked block. I was one month out of the extended warranty (of Course) but the Honda Dealer went to bat for me (have owned 3 Odysseys from them) and got 2/3 of the cost covered so I paid 1/3 and got a new block at 198k, not going to complain. I have looked at new cars and would love one, but this thing is bullet proof and my daily driver. Put about 100 miles a day on it for years but now it's about 10 to 20 but still driven every day.
241644
09 Civic LX. This may sound a little insane, but I just passed 388k. I have been driving for both Lyft and Uber for the past 4 years, plus random trips a couple of hours from home to visit nearby relatives, etc. I do my own maintenance, for the most part, ONLY Pennzoil Platinum Plus synthetic oil, and Castrol multi import transmission fluid which I change every 20K. Still runs great!
