1 - 1 of 1 Posts
My 2 concerns, the 90 degree fitting had some threads left out (connecting it to the rear of the caliper), i didnt want to break it so left it as tight as i could get it w/ locktite, that good enough?
2nd one, I used 2 washers (top and bottom e/ side) to have the bolt sit perfectly flush on the bracket but the caliper is a tiny bit uncentered w/ it being more inside. (sorry, trying to make it make sense)..
Also, i just put anti-squeak on the pads, w/out shims, no problem, may squeak later I assume
Any help from anyone w/ this exp would greatly help. I wasn't able to find any leaking but jus trying to assure myself. Thanks
1 - 1 of 1 Posts
