1 - 4 of 4 Posts
i dont think you checked..... its just .5in wider then the stock wheel size you can most def fit them with stock tire size.
figure it out from the ones in red......
http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
or try this VVVVVVVVVVVVVVVV
added: calculator for wheel fitments - offset calculator
Wheel / tire size calculator / comparer - RIMS-N-TIRES
UPDATE 10/17/06
Si/Coupe
16x7 50mm offset 205/55-16 (No drop)
17x7 45mm offset 215/45-17 (Stock Si Fitment)
17x7 40mm offset 215/45-17 (No drop)
17x7 55mm offset 215/45-17 (1.5" Drop)
17x7.5 38mm offset 225/40-17 (1.5" drop)
17x7.5 42mm offset 225/45-17
17x8 45mm offset 235/40-17
17x8 42mm offset 235/40-17 (1.4" drop w/Eibach Sportlines)
17x8 35mm offset 225/45-17
18x8 35mm offset 225/40-18 (HFP Suspension)
18x7.5 38mm offset 215/40/18 (w/ Skunk2 Drop)
18x7.5 40mm offset 225/40-18
18x7 45mm offset 215/40-18 (HFP Wheel Fitment)
18X8.5 45mm offset 235/35-18
18x7.5 50mm offset 215/40-18 (No Drop)
18x7.5 50mm offset 215/40-18 (1.5" drop)
18x7.5 45mm offset 225/40-18 (1.4" drop)
19x7.5 44mm offset (3mm spacers installed {41mm effectively}) 225/35-19 (Lowered 2.25" Tein SS)
19x8 40mm offset 225/35-19 (Dropped on HFP springs .5" drop or Tein SS 2.25" Drop)
20x7.5 45mm offset 225/30-20
20x8.5 35mm offset 225/30-20 (1" drop w/Eibach Prokit)
Sedan
17x7 35mm offset 215/40-17 (No Drop)
17x7 42mm offset 225/45-17 (lowered on Eibach Pro Kit)
17x7 55mm offset 205/45-17 (Lowered 2" Neuspeed Springs)
17x7 45mm offset 205/45-17 (Lowered 2" Neuspeed Springs)
17x7.5 45mm offset 215/50-17
17X8 43mm offset 225/45-17 (Lowered on Eibach Pro kit)
18x8 48mm offset 225/40-18
18x8 45mm offset 225/40-18 (lowered on Eibach Pro Kit with Negative rear camber)
1 - 4 of 4 Posts
