1 - 13 of 13 Posts
anyone have a clue where i can get a new primary and secondary o2 sensor for my 06 SI?!? im tired of running around with fouled up sensors, CEL, and more than likely running little rich because of it. If anyone has a clue that'd be great dealership wants over $100 for each just for the part
HondaAutomotiveParts.com
You need # 16 & # 17. Your welcome.
your local autparts store, checkers pepboys autozone will carry them, so will eBay, as well as those OEM honda parts stores on the web.
Discussion Starter #8
not a single napa autozone or pepboys within 10 miles carries them there arent even part numbers listed on their comps. and none on ebay
If you're not crafty at figuring out which wires connect to which, soldering etc, stick with OEM parts, plug-in and go.
the 08 si comes with a WB?
i used to have an ep3 and I know it came with a WB sensor from the factory, does the 2008 SI sedan does as well?
the reason I ask I that I have an innovative LC-1 and I want to know if I need it in the SI or not
What CEL are you getting? I'm getting a CEL saying my primary oxygen sensor's circuit is malfunctioning or something along those lines... I can't remember the exact description right now. I kinow I'm running rich on my Greddy turbo w/base map.
1 - 13 of 13 Posts
