1 - 2 of 2 Posts
Right now I have 17x8 or 17x9 I cant remember at the moment but I have 205/40/17 tires rn. I'm probably gonna get new wheels and tires and wanna go to an a 18x9 with 215/45/18. If anyone has this similar setup or knows of anyone with this setup and has any input I would greatly appreciate it. Oh I forgot I have skunk2 lowering springs on 07 SI sedan
What's the offset on this new set of wheels? The offset is what creates a lot of clearance issues, although that new wheel will all around be a tight fit with it being both an inch taller and 2 inches wider than stock. If you are already running a 17x9 wheel then you might not have to do much more work though if you are ok with running some negative camber.
1 - 2 of 2 Posts
