1 - 20 of 23 Posts
· Registered
Hi guys im buying a new set this month. Im looking at 3 rims right now but idk which one to pick. Tell me whats your opinion
This are my current wheels:
SUSPENSION: Skunk2 Pro Street
These are the wheels Im looking at:
17x7 is the size
Motegi SP10
Konig Heatsink
Konig Runaway
Konig Foil
WHAT DO YOU GUYS THINK?
thanks in advance
· Registered
yeah i love my motegi dp6 but they are too big and it rubs a bit with my suspension setup
heres a photo of my car with stock rims and DROPPED at the lowest coilover setting.
· Premium Member
why dont u just raise up the car a bit then???
· Registered
Discussion Starter · #8 ·
well thats the purpose of me looking for a new rims.
i like riding dumped lol
i might just buy new tires for the motegi dp6 its too wide 225 i might change it to 215
· Registered
Discussion Starter · #10 ·
If you are looking for new wheels why limit yourself to just Motegi and Konigs? So many other brands out there. Of your choices, I'd stick with what you've got.
Well these brands are pretty affordable and pretty durable
and also lightweight
im trying to go not that expensive on the wheel since I might trade in my car in the summer or a year from now
do u have any brands that you would recomend?
· Registered
Discussion Starter · #11 ·
current specs of wheels and tires?
Motegi DP6 18x7.5 offset 45mm
Toyo Proxes 225/40/18
This wheels don't rub if the car was .25 higher than the lowest setting
The Gold one is 18x7.5 but dont know the exact offset but it rubs on fast turns and bumps
· Registered
Discussion Starter · #13 ·
uhmm ill be honest with you i dont exactly know
I know I have the skunk2 camber arms
when i got it aligned the dealer showed me its within the factory spec but that was when i had my TIEN S-TECH
i havent gotten an alignment since the Skunk2 Pro S
I dont have camber bolts in the front
· Premium Member
thats probably why... you are on pro-s right? Do those come with the adjustable camber plates???? if not get some camber bolts.. dial in
-1.5 F
-1.0 R
0/32 toe for both.
· Registered
Discussion Starter · #15 ·
-1.5 F
-1.0 R
0/32 toe for both.
yeah its Skunk2 Pro S
It doesnt have adjustable camber plates. It uses the stock top hat for the top mounting.
You think that will solve it?
· Registered
17x7 is the size
Motegi SP10
Konig Heatsink
Konig Runaway
Konig Foil
thanks in advance
There are various brands that you can choose from depending on the kind that you are comfortable and that which suits the car. Check out: www.clicktire.com . They have a great range of tires and wheels and I’m sure you will find the right ones to suit your needs.
1 - 20 of 23 Posts
