quick question about the tweeters in the si. if the tweeter is crossed over at the amp why does the si wiring diagram on this site say you pick up the tweeter signal from the wires at the tweeter instead of off the amp like the other speakers. reason i ask is because i am running an audio control lc8 and i don't want to have to run wires from the tweets all the way back to the trunk.
also, does anyone know what the crossover points are on the factory amp? since i am using the lc8 to get the signal from the factory amp which then sends the signal to my aftermarket amps i don't want to use the crossovers on the aftermarket amps and have two different sets of crossover points.
thanks. ps- i used dynamat everywhere in the car and it sounds awesome! (doors, trunks, floors, rear deck)
