1 - 7 of 7 Posts
My 07 si sedan is a dialy driver, I just ordered the skunk2 headers, and 70mm exhaust. Also have a cte intake, and will do a hondata reflash after I install the header/exhaust.
I'm reading adding aftermarket motor mounts will stop the header from hitting the subframe.
The reviews I'm reading on the boomba mounts seems like they vibrate a lot and will ruin a daily driver car.
I see innovative has different stiffness. Should I get the red-street? Or black-track? I want to make sure the header doesn't hit the subframe. But also want to make sure it remains a nice car to drive daily.
Discussion Starter · #4 ·
Would the single hasport rear mount be enough to fix the issue of the skunnk2 header hitting the subframe
innovative 75's are awesome!
Boomba mounts will stop your motor from rocking forward and backward. However, you will loose a lot of your comfort and increase the sound inside your cabin. You can keep your get the same benefit from using a torque damper and still retain the comfort from your car and keep the sound levels down to a minimum inside your ride.
1 - 7 of 7 Posts
