What else should I do while I am doing DCRH..
894 views 16 replies 7 participants last post by  nalinc23
#1 ·
Is it worth getting the Hondata or Corsport Intake Manifold Heat Gasket while I am doing the header? Does it make a noticeable difference? Also where can I buy the defouler that will eliminate my CEL and is it easy to install?
#12 ·
Well I got my hangers in and they are a bit small. The real problem seems to be that the DCRH hanger bar extends a little too far forward and butts up against my front sway bar some times. My solution is probably going to be to saw some of it off and install the new hangers once I bore the holes out to a larger size. Only reason I'm cutting the hanger bar is because I can't even get the current hanger off due to how close the edge of the hanger bar is to the sway bar.
