Hi Guys -
Thanks for the welcome. We don't blame you for being surprised. Flowmaster is more well known for domestic muscle car parts, but we have several options in both the Flowmaster and Hushpower brands that will work on the 8th gen.
We often get asked, "Does Flowmaster/Hushpower make anything for imports? " The answer is, absolutely – most notably the
dBX line of high performance Hushpower mufflers.
The
dBX is a specially designed version of the Hushpower Pro Series muffler that is reliable and high performance.
For a stock 2008 Civic, we'd recommend something like our dBX muffler with 2.25-inch inlet/outlet dimensions.
The system is easy to install, requiring only one simple tubing cut and a slip fit clamp to attach using the factory hangers and mounts.
The final result is better tone, better throttle response and improved performance and mileage. The performance sound is significantly better with no drone characteristics , comfortable at both around town and cruising speeds.
We are truly interested in your opinions and suggestions. We'll simply use this section and our sponsorship to answer questions if you have them and to share installs and videos when we come out with new products.
We also might occasionally need test and R&D cars, so we'll post here when we have openings.
Thanks again for letting us join your community. We look forward to becoming a part of it.
