1 - 8 of 8 Posts
Weapon R Intake
Hi Merry Christmas,
My wife just bought one of your intakes systems for me as a Christmas present. I have begun the install process and noticed the intake tube does not align up with the throttle body.
Civic Si 2007
Honda 06-07 Civic (Si WR-SECRET-301-158
Only) Weapon-R Secret
Weapon Intake System
(301-158)
Please see attached photos, was the wrong model shipped to me?
most of the short rams won't line up 100% till you get the angle exactly right. plus in the pic it doesnt show the rubber fitting from the intake tube to the throttle body tube. i would suggest putting that rubber piece on the intake. getting it all lined up on the throttle body. bolting it all together. THEN working on getting the mount by the filter secured. once you get it on the throttle body its much easier to mess around with the filter area to get it lined up.
I am aware of the rubber coupling but even with the coupling it seems the air flow would be restricted with such an angle. I have installed other intakes and have never seen such gab in design. I hooked the unit up just with out the final brackets and the engine seemed to run a bit rough. I am also in need of a new MAF sensor?
1 - 8 of 8 Posts
