1 - 9 of 9 Posts
I had a clutch clicking noise fixed under warranty, where they re-lubed the hydraulic component of the master cylinder around 30k. I'm now at 45k, but the problem has come back.
Since I'm no longer under factory warranty, can I still be covered if the work they did to try to fix the problem did not work? Car is 07 Civic LX.
TIA!
i believe they only checked the problem and lubed it, so no replacement of any parts. i'm guessing i'm going to have to pay for it now if i want it to be fixed?
Discussion Starter #8
i read somewhere else in a thread that the clutch assembly is not a part of drivetrain?
Discussion Starter #9
Ok so looked it up myself. Here's the details on a 2007 Civic LX 5spd 2 door coupe:
Engine
Cylinder block and head and all
internal parts, timing gears and
gaskets, timing chain/belt and cover,
flywheel, valve covers, oil pan, oil
pump, intake and exhaust manifolds,
engine mounts, engine/powertrain
control module, water pump, fuel
pump, seals and gaskets.
Transmission and Transaxle
Case and all internal parts, torque
converter, transfer case and all
internal parts, transmission/
powertrain control module, seals
and gaskets.
Front-Wheel-Drive System
Final drive housing and all internal
parts, driveshafts, constant velocity
joints, front hubs and bearings, seals
and gaskets.
Rear-Wheel-Drive System
Differential housing and all internal
parts, propeller shafts, universal
joints, driveshafts, constant velocity
joints, rear hubs and bearings, seals
and gaskets.
For a list of items not included
in this warranty, please refer to
page 9.
1 - 9 of 9 Posts
