Hey guys, I'm posting this because I was one of many people who complain about the way this car shifts. Maybe it was just our cars, maybe it was us- either way, I have a fix that *many of us may already know about* but I'm here to tell you *my personal experience*.
So I had this trouble getting into 2nd for some time on hard pulls and when I was going all the way up to the redline. Other gears also began to get notchy (car is at 20k miles). It was very discouraging to my shifting confidence.
I thought to myself, a short shifter (SS) of some short might just be what I need! So I bought the Comptech SS Adapter and it didn't help me at all! In fact the problem seemed to get worse....a notchy 3rd gear (after the 3rd gear set and shift forks being replaced too) and a 2nd that was just so rough to get in on hard pulls. (I'm not blaming or bashing the Comptech SS, in fact it produced a great reduction in shift throw)
I sold the Comptech a few days later on here and I went back to stock. I had the same problem. I didn't enjoy driving as much as I should've been! So here's where I fixed those problems.
First, I changed the Honda Manual Transmission Fluid to Amsoil Synthetic Syncromesh. WOW what a difference, every gear was smooth as hell and I was loving the way the car shifted. It went from a feeling of shifting with a piece of sandpaper on either side of the stick to a stick of butter on either side. You can order it here: AMSOIL - Synthetic Manual Synchromesh Transmission Fluid (MTF) and you will need to buy 2 qts. since the car takes 1.6 qts (at least on my 07 Si Coupe). This costs $32 total for the 2 qts.
I was very satisfied but I knew I wanted a shorter shift now. So I bought the Mugen Quick Shifter and things got even better. That stick of butter on either side now felt like warm melting butter it's just so smooth. My confidence is way higher now and that in turn also helps me to shift much better. I don't miss 2nd on any hard pulls now and every gear goes in so smoothly (in both cold and warm conditions). In order to get this Mugen QS without owning a Mugen you will need some help so PM me, thankfully, others have helped me to get mine. It goes for $206 total.
These 2 combined are SO worth it for the car, and I bet if you already have some other short shift adapter (even that Comptech) just changing the MTF would help you so much...although I doubt any adapter will work as well as the full Mugen setup according to my personal experience and to the opinions of others who've tried both SS Adapters and the Mugen QS.
Well I hope this helps some of you guys because it's a terrible thing when you can't drive this fun car the way you want to. Just PM me if you want to know anything else and once again, I know this has all been stated but this is my own personal experience with this MTF change+Mugen bolt on modification.
PS- No...none of the SS Adapters will fit on the Mugen QS...if you install it, you will understand like those that did, there is no where near enough room.
