VSA light stays on
1144 Views 1 Reply 2 Participants Last post by  Chaos Pilot
So I did a clutch in my FA5 and had to drop the subframe but I suspended the rack safely so it never came disconnected from steering column but now that I’ve got everything back together the VSA light just stays on I’ve tried holding the button and turning the car off and back on so what can I check or replace or what could be wrong with the system?
1 - 2 of 2 Posts
Is it a stiffer clutch? Stock or stage 2? Adjusting aftermarket clutches is different from stock. You dont follow Hondas guidelines for adjusting an aftermarket clutch.
Did you adjust the two switches located on the clutch bracket? They have a little pin that is pushed in or out depending on clutch position.
1 - 2 of 2 Posts
