http://www.8thcivic.com/forums/car-builds/257682-sidannys-skrate-racekoars-scream-little-civic-scream-build-n-skrit.html
Modifications:
Engine/Performance
Ct-Engineering Supercharger (Ported by Stegmeier)
Mercracing 3.0" blower pulley
Mercracing SC inlet
Mercracing Stage 2 Aftercooler
OEM Acura ZDX TB
P2R P149 Gasket
T1R IAT sensor in the manifold
AFI/RCI Bosch Modified 850cc Injectors
Walbro 255lph fuel pump
Crushed FPR
Hondata 4 Bar Map Sensor
Golden Eagle IMG
Gates K070810 V-Belt
NGK-BKR9EIX Spark Plugs
Stock Idler pulley mod
DIY 3.5" Cold air intake
Skunk2 Alpha race header
Invidia Q300 exhaust
Hondata Flashpro (Tuned by VitViper)
Supercharger Boost By Gear
Napa Part #7777 upper radiator hose
Injected Upper Dogbone mount
Injected front mount
Hasport FDRR 70a
Yospeed battery tie down
Hybrid Racing shifter cable bushings
Wheel/Suspension Upgrades
Redshift Coilovers/Koni SA Sport shocks (yellows) 350F/450R
Progress 22mm RSB
SPC front camber bolts
SPC v2 rear camber arms
Enkei RPF1 17x9 +35 - Mag Blue (summer)
Falken Azenis FK453 235/40/17 (summer)
2009 Stock Si Wheels (winter)
Continental ExtremeContact DWS 215/45/17 (winter)
Meyle Platinum brake rotors
Stoptech street pads
Techna-fit SS brake lines
ATE DOT4 super blue brake fluid
Exterior Modifications
CustomLightz Mini H1 headlight retrofit
6000k HIDs
45% Window Tint
Grafixpressions Red rear turn signal overlays
LED Projector reverse bulbs
LED Number plate lights
Interior Modifications
XLR8 dual gauge pod
AEM Boost gauge
AEM UEGO gauge
OEM All season floor mats
OEM Trunk tray
I <3 Boobies Wristband on shifter
Save the Manual Wristband
LED Map lights
LED Dome light
LED Trunk light
Karcepts Delrin Shirft Knob
CTR Shift boot
Sickspeed shifter extender
TWM Stage 2 full replacement shifter
Aluminum base bushings
Strut King dead pedal
I.C.E
Beltronics i955 (Hardwired)
Armrest full of Awesome Sauce
