who shall be 8thCivic ROTM September??
  • Mikey6p
    Votes: 15 12.7%
  • SiDanny
    Votes: 31 26.3%
  • LouGraySI
    Votes: 19 16.1%
  • Thug108
    Votes: 13 11.0%
  • PhilaCivic
    Votes: 40 33.9%
  • Total voters
    118
  • Poll closed .
1 - 20 of 36 Posts
Administrator
http://www.8thcivic.com/forums/car-builds/121423-mikey6ps-asm-fa5.html
Modifications:
Performance:
  • Custom 3" Intake
  • GoPower 3" v3 "Quiet" Exhaust
  • J35 Throttle Body
  • Ported Intake Manifold
  • Exedy KHC10 OEM replacement clutch
  • FD2 5.062 Final Drive
  • P2R Throttle Body Spacer and Thermal Gaskets
  • P2R Intake Manifold Gasket
  • Hondata FlashPro, tuned by VitViper
  • Hybrid Racing Transmission Bushings
Suspension:
  • 18x9.5+32 Custom 2-Piece Step Lip 6061 Barrel Super Advans SA3R
  • 235/40/18 Bridgestone Potenza RE760 Sport
  • Koni Sport Yellow Shocks
  • SteebSpecd Spring and Sleeve Setup, XXX F / 14k Rear
  • SPC Front Camber Bolts
  • Buddy Club Rear Camber Arms
  • Progress Rear Sway Bar
  • DIY super heavy duty endlinks
  • Hawk HPS brake pads
  • ABT Drilled/Slotted Rotors
  • Pentosin Super DOT4 Brake Fluid
Exterior:
  • 17% tint
  • Mugen Window Visors
  • VIS "doluck" CF trunk
  • DEPO FD tails
  • RR Fender Flares
  • Replica Mugen Sideskirts
  • JDM emblems with Blue Grafxpression overlays
  • Skunk2 Valve Cover Hardware
  • DEPO FD1 headlights, retrofitted
  • -Tsx Projectors
  • -Orbit Shrouds
  • -Bezel Painted Black
  • -Shroud Painted Silver
  • -Philips 85122+ Bulbs
  • Morimoto 55w 5000k Ballasts/Harness
  • VIS Fenders/bumper/hood
  • FD2 Sidemarkers
Interior:
  • Pioneer AVIC D3 Head unit/Ipod Connection/Bluetooth unit
  • Wink Mirror
  • CSX Center Bin
  • TWM M1 Abrams Shift Knob
  • Corsport Short Shifter
  • Corsport Shifter Base Bushings
  • Corsport Rear Pillar Bar
  • Red door panel inserts
Thoon.
http://www.8thcivic.com/forums/car-builds/257682-sidannys-skrate-racekoars-scream-little-civic-scream-build-n-skrit.html
Modifications:
Engine/Performance
Ct-Engineering Supercharger (Ported by Stegmeier)
Mercracing 3.0" blower pulley
Mercracing SC inlet
Mercracing Stage 2 Aftercooler
OEM Acura ZDX TB
P2R P149 Gasket
T1R IAT sensor in the manifold
AFI/RCI Bosch Modified 850cc Injectors
Walbro 255lph fuel pump
Crushed FPR
Hondata 4 Bar Map Sensor
Golden Eagle IMG
Gates K070810 V-Belt
NGK-BKR9EIX Spark Plugs
Stock Idler pulley mod
DIY 3.5" Cold air intake
Skunk2 Alpha race header
Invidia Q300 exhaust
Hondata Flashpro (Tuned by VitViper)
Supercharger Boost By Gear
Napa Part #7777 upper radiator hose
Injected Upper Dogbone mount
Injected front mount
Hasport FDRR 70a
Yospeed battery tie down
Hybrid Racing shifter cable bushings
Wheel/Suspension Upgrades
Redshift Coilovers/Koni SA Sport shocks (yellows) 350F/450R
Progress 22mm RSB
SPC front camber bolts
SPC v2 rear camber arms
Enkei RPF1 17x9 +35 - Mag Blue (summer)
Falken Azenis FK453 235/40/17 (summer)
2009 Stock Si Wheels (winter)
Continental ExtremeContact DWS 215/45/17 (winter)
Meyle Platinum brake rotors
Stoptech street pads
Techna-fit SS brake lines
ATE DOT4 super blue brake fluid
Exterior Modifications
CustomLightz Mini H1 headlight retrofit
6000k HIDs
45% Window Tint
Grafixpressions Red rear turn signal overlays
LED Projector reverse bulbs
LED Number plate lights
Interior Modifications
XLR8 dual gauge pod
AEM Boost gauge
AEM UEGO gauge
OEM All season floor mats
OEM Trunk tray
I <3 Boobies Wristband on shifter
Save the Manual Wristband
LED Map lights
LED Dome light
LED Trunk light
Karcepts Delrin Shirft Knob
CTR Shift boot
Sickspeed shifter extender
TWM Stage 2 full replacement shifter
Aluminum base bushings
Strut King dead pedal
I.C.E
Beltronics i955 (Hardwired)
Armrest full of Awesome Sauce
ThpoonThports
http://www.8thcivic.com/forums/car-builds/293462-we-showin-they-goin-g-i-chos-gangsta-grey-mustache-ride.html
Engine/Performance Modifications
Skunk2 3.5" Polymer CAI
USDM Mugen Quick Shifter
Hybrid Racing Shifter Cable Bushings
Hybrid Racing Shifter Base Bushings
Invidia Q300
SSR 4-2-1 Race Header
P2R Throttle Body Spacer with 2 Gaskets
Hasport Rear Mount 70A
3M Injected Dogbone mount
Hondata FlashPro
Tuned by VitViper
Spoon Calipers
NGK Iridium 7 Spark Plugs
Koni STR.T Front Struts
Koni Sport Rear Shocks
Neuspeed Sport Springs
Godspeed Camber Arms
Ingalls Front Camber Bolts
Beaks Candy Red Rear Lower Tie Bar
Summer Wheels: ADVAN RG-D 17 x 8.5 + 33
Summer Tires: Falken Azenis 453
Winter Wheels: Enkei Stock Evo8 17 x 8 +38
Powdercoated True White
Winter Tires: Continental ExtremeContact DWS 225/45
20% Tint all around
OEM Window Visors
09 Front Conversion
09 HFP Front Lip
09 OEM Fogs
Nokya Yellow Fogs
Nokya Yellow DRLs
Front and Rear JDM Badges
EGR Rear Roof Visor
RX330 Retrofitted Headlights w/color mod and E46 shrouds
Gloss Black Roof Vinyl
Mugen Rep Side Skirts
USDM OEM Mugen Rear Diffuser
USDM OEM Mugen Wing
43 LED Rain Light
iJDMtoy Projector Reverse Lights
VIS Carbon Fiber Civic RR Hood Color Matched GGM
"DOHCK20Z3" Side Decals (removed iVtec decals)
Digital Camo Hydro dipped Valve cover, fuse box cover and ecu cover. All with Mercedes Silver Base Coat.
CTR Shift Boot
Blox "Limited Series" 490 Spherical shift knob Neochrome
Interior LED Map/Dome Lights
CorSport red "H"
Strut King Dead Pedal
Broadway Mirror
OEM All Weather Mats
I.C.E
2 10" Alpine Type E
Rockford Fosgate 1000w Amp
Pioneer AVH-X5500BHS Multimedia DVD Receiver
Engine:
Ebay cold air intake
Greddy Ti-C axleback
Optima Red top
Suspension/Wheels/Brakes:
Mugen Gp powdercoated high gloss black
Falken FK452 225 40 18
Tein Monoflex with edfc
Skunk2 rear camber arms in gold
Beaks bar
Progress rear sway bar 22mm
Bf Goodridge SS brake lines
Acura TL-S front brake calipers with S2000 rotors
Rear brake drums converted to discs
Exterior:
FD2 Carbon Fiber trunk with FD1 tail lights
Front and Rear JDM black Honda emblem
Mugen RR Carbon Fiber full front end
LED side marker upgrade
LED city light upgrade
PWJDM rear tow hook
Interior:
Full civic si swapped interior
Red JDM carpet
JDM hazard button
CTR push start
Alpine SPR-60C front and rear component speakers
Alpine PDX-4.100M
Alpine PDX-1.1000
Pioneer AVIC Z110BT upgraded to Z140
Kicker C124 Single 12" 500W
Red door inserts
Sickspeed short shifter adapter
Replica Mugen pedal set
Mod List:
Exterior::
3M Paint protection
35% tint
HFP Front lip
Authentic Mugen visors
Authentic Mugen Rear diffuser
Authentic Mugen sideskirts
Authentic Mugen License plate bolts
Custom Mugen Inspired Yospeed plate frame
VIS CF Mugen RR Hood- color matched
VIS CF USDM trunk- color matched
CF-Spec CF Grille
JDM Front emblem
JDM Yellow fog overlays/ Nokya Bulbs
08 Si Stockies (winter)
BBS RS 17x8+35 & 17x9+35 (Refinished by 4Ever Kustoms)
BBS Red centercaps from Japan
Michelin Pilot Exalto PE2 215/45/17
Spoon Calipers
Debadged Civic
License plate LEDS
6k Hids
Hyper white license plate LED
Canibeat Frame
Nokya yellow DRLs
3M Carbon fiber wrapped trunk garnish
Subaru STI S204 splitter
Interior:
Authentic Mugen door sills
Authentic Mugen mirror cover
Authentic Mugen CF shift knob
Authentic Mugen Equipped badge
Authentic Mugen Limited Edition Shift badge
Bride center console
Bride shift boot
Bride door inserts
Bride armrests
Weathertech Floor Liners
OEM trunk tray
OEM JDM key fob
CF-Spec CF Door switch trim
FaVES CF steering wheel trim
CF shift trim
CF dash
Strutking dead pedal
J's racing JDM Honda steering wheel emblem
Hyper white Map LED
Hyper white Dome LED
Hyper white Trunk LED
Engine/Suspension:
Authentic Mugen reservoir cover
Authentic Mugen oil cap
Authentic Mugen radiator cap
Authentic Mugen exhaust
Hondata FP
Function & Form type 2 coils
Skunk 2 camber arms V1
Vibrant race header w/HFC
T1R CF intake
CF-Spec CF Intake manifold cover
CF-Spec CF Spark plug cover
CF-Spec CF Cooling plate
PWJDM CF Fuse Box Lid
PWJDM CF ECU Cover
Custom Mugen Inspired Yospeed battery tie down
Beaks lower tie bar
Domo reservoir cover
Candy Apple Red engine cover
Weksos engine spikes
1 - 20 of 36 Posts
