who shall be 8thCivic ROTM November??
  • Mikey6p
    Votes: 6 6.1%
  • MrCivicSi2010
    Votes: 9 9.2%
  • tiZZle2.0
    Votes: 22 22.4%
  • element600rr
    Votes: 8 8.2%
  • LouGraySI
    Votes: 39 39.8%
  • fg2taffysi
    Votes: 14 14.3%
  • Total voters
    98
  • Poll closed .
1 - 20 of 29 Posts
Administrator
http://www.8thcivic.com/forums/car-builds/121423-mikey6ps-asm-fa5.html
Modifications:
Performance:
  • Custom 3" Intake
  • GoPower 3" v3 "Quiet" Exhaust
  • J35 Throttle Body
  • Ported Intake Manifold
  • Exedy KHC10 OEM replacement clutch
  • FD2 5.062 Final Drive
  • P2R Throttle Body Spacer and Thermal Gaskets
  • P2R Intake Manifold Gasket
  • Hondata FlashPro, tuned by VitViper
  • Hybrid Racing Transmission Bushings
Suspension:
  • 18x9.5+32 Custom 2-Piece Step Lip 6061 Barrel Super Advans SA3R
  • 235/40/18 Bridgestone Potenza RE760 Sport
  • Koni Sport Yellow Shocks
  • SteebSpecd Spring and Sleeve Setup, XXX F / 14k Rear
  • SPC Front Camber Bolts
  • Buddy Club Rear Camber Arms
  • Progress Rear Sway Bar
  • DIY super heavy duty endlinks
  • Hawk HPS brake pads
  • ABT Drilled/Slotted Rotors
  • Pentosin Super DOT4 Brake Fluid
Exterior:
  • 17% tint
  • Mugen Window Visors
  • VIS "doluck" CF trunk
  • DEPO FD tails
  • RR Fender Flares
  • Replica Mugen Sideskirts
  • JDM emblems with Blue Grafxpression overlays
  • Skunk2 Valve Cover Hardware
  • DEPO FD1 headlights, retrofitted
  • -Tsx Projectors
  • -Orbit Shrouds
  • -Bezel Painted Black
  • -Shroud Painted Silver
  • -Philips 85122+ Bulbs
  • Morimoto 55w 5000k Ballasts/Harness
  • VIS Fenders/bumper/hood
  • FD2 Sidemarkers
Interior:
  • Pioneer AVIC D3 Head unit/Ipod Connection/Bluetooth unit
  • Wink Mirror
  • CSX Center Bin
  • TWM M1 Abrams Shift Knob
  • Corsport Short Shifter
  • Corsport Shifter Base Bushings
  • Corsport Rear Pillar Bar
  • Red door panel inserts
MrCivicSi2010 CPB FG2
Modifications:
Performance
Skunk2Racing Composite Intake
Karcepts Throttle Body Spacer
Hybrid Racing Fuel Rail
B&M Fuel Pressure Guage
Hybrid Racing Tucked Fuel Line
Hybrid Racing Shifter Cable Bushings
Hybrid Racing Short Shifter
Skunk2Racing Alpha Race Header
Invidia 70mm N1 Catback Exhaust
ARC Rad Cap
Hondata Flashpro - Dyno Tuned by Steve from Etunz at Speed Factor Racing
Ktuned Coolant Passage
Ktuned idle air assist delete
EVAP System Delete
Ktuned Brake Booster Tucked Line
Vibrant Valve Cover Filter
Suspension
HSD HR Monotube Coilovers
Stoptech 4 Piston Big Brake Kit 13" 2 Piece Slotted Rotors
Motul 5.1 Brake Fluid
WedsSport TC105N in Titan Silver 17X9 +35 (all around)
Yokohama AD08 225/45/17 (all around)
Buddy Club Front Lower Ball Joints
NRG Front Upper Strut Bar
Hasport 62a Engine Mounts
Exterior
ARC Front Winglets
OEM HFP Front Lip
OEM HFP Side Skirts
OEM HFP Rear Lip
OEM Type R Front Red H
OEM Type R Rear Red H
T1R Hood Dampers
J's Racing Teal Valve Cover
Skunk2Racing Black Valve Cover Hardware
Spoon Sports Kevlar Coil Pack Cover
6000K HID Low Beam
6000K HID Fog Lights
AVS Window Visors
LED Rear License Plate Lights
LED Reverse Lights
PWJDM Battery relocate
Odyssey Dry Cell Battery PC680
Debadged Civic Trunk Emblem
Tinted 3rd Brake Light
BWR Hood Spacers
Spoon Sports Resivour Covers
FD2 Type R Oil Dip Stick
Interior
Spoon Sports Duracon Shift Knob
J's Racing Steering Wheel Emblem
Razo Rear View Mirror
OEM Rubber Floor Mats
OEM Non-Navi Stereo (Canadian cars didnt come with navi)
LED Interior Lights
DSC_0179 by tiZZle2.0, on Flickr
DSC_0186 by tiZZle2.0, on Flickr
Untitled by tiZZle2.0, on Flickr
My Build:
http://www.8thcivic.com/forums/car-builds/327665-tizzles-overdue-over-budget-semi-low-key-k24-build.html
Engine:
FlashPro
k24a8 block
J37 throttle body
P2R IM gasket
RBC IM fully ported
RSD 3.5" CAI
K Tuned fuel rail
NGK 2668 plugs
RDX 410cc Inj
Scion TC clips
OEM headstuds
Cosworth 1.1mm head gasket
Supertech 92lb valvetrain
Supertech flat ex valves
Drag Cartel 3.2
HPT timing chain guide
OEM Z3 tensioner
Supertech 88mm 12.5:1 c/r piston
K1 connecting rods
ACL main bearings
OEM rod bearings
RRC oil pump
Exedy Stg1 clutch
CC 11lb flywheel
9th gen sixth gear
FD2 5.06 final drive
Hasport full 70a mounts
Skunk2 Megapower v2 Header
Invidia Q300 exhaust
Exterior:
20% tint all around
45% tint on front windshield
Mugen window visors
Red JDM H badges
Red taillight overlays
Nokya yellow drl
Nokya yellow fog lights
OEM half mask
Suspension/Wheels:
Buddy Club N+
SPC camber arms
Project Kics r26 lug nuts
17x9 +45 SBC Enkei RPF1
Falken 453 235/40/17
build page ..http://www.8thcivic.com/forums/introduction-pictures/358418-element600rrs-white-thrash-build.html
MOD LIST
DRIVE TRAIN
HYBRID RACING 3.5INTAKE
J35 THROTTLE BODY
RDX INJECTORS
HYBRID FUEL LINE TUCK
RRC INTAKE MANIFOLD
SKUNK ALPHA HEADER
THERMAL 3IN EXHAUST
FLASH PRO
VIT TUNE
TWM SHORT SHIFTER
TWM BUSHINGS
HYBRID RAIL / GUAGE
EXEDDY 9.8 LBS FLYWHEEL
EXEDDY STAGE 1 CLUTCH
CTR FINAL DRIVE 5.06
CARBONTECH CARBON SYNCROS
HYBRID EM1 CM / STAINLESS CABLE SET UP
SPOON MAG PLUGS OIL / TRANS
UNIQUE MODS SKID PLATE
WHEELS / SUSPENSION/ BRAKES
ENKIE KOJINS 17X8 +35 235 40 17 DIREZZA ZIIS ( i love these tires even more than the ZIs )
OZ ALLEGERITA'S 17x8 +48 WITH 15MM SPACERS +33 dunlop star specs 235 40 17
NEUSPEED SPRINGS ( KONI YELLOWS ).
LOWER FRONT ARM BUSHINGS FORE AND AFT ( energy )
SPOON CALIPERS MONO BLOCK ( EURO ACCORD R )
TL TYPE S MASTER CYC
EBC BLACK DASH FRONT ROTORS
HAWK HPS FRONT PADS
PASSWORD REAR ROTORS
HAWK HPS REAR PADS
PROGRESS SWAY BAR ADJUSTABLE 25MM WITH ADJUSTABLE END LINKS
GOODRIDGE STAINLESS BRAKE LINES
MOTUL RBF600 FLUID
PROJECT KICS R40 BLACK LUGS
RUN 15MM SPACERS WITH THE OZ'S TO MAKE THE OFFSET 32MM
EXTERIOR
MUGEN REAR LIP ( AUTH )
MUGEN SIDES ( REP )
MUGEN RR FRONT BUMPER US SPEC ( REP OF COURSE ) WITH LED'S AND OPTIONAL LIP
MUGEN WINDOW VISORS
HEADLIGHTS (MORIMOTO DS2 ) PAINT MATCHED TAFFY WHITE
JDM TRUNK ( CARBON SEIBON )
JDM TAILS ( DEPO 09 + ) SMOKED LOWERS
JDM BADGES
SEIBON MUGEN GT REP ADJUSTABLE TRACK WING
FLUSH MOUNT STAINLESS BOLTS ATTACHING ALL SKIRTS LIPS AND EXT PARTS
INTERIOR
RECARO SRD SEATS
VANNER RAILS
ALACANTRA STEERING WHEEL WITH 1/8 IN PADDING ADDED TO MAKE THE WHEEL THICKER RED DIAMOND STITCHING
CTR OEM SHIFT BOOT
ZERG INDUSTRIES CARBON TRIM AROUND STEERING WHEEL / SHIFTER
PIONEER AVIC X9400BT ( FACTORY AMP BYPASSED )
MB QUARTS SEPARATES FRONT / REAR
ROCKFORD P3 SUB
AMP PPRECISION 600X1
SMD INTERIOR LIGHTS
MUGEN ALM SHIFT KNOB
CTR PUSH START ( JOON RELAY HARNESS )
DRESS UP
IVTEC LOGOS REMOVED
PASSOWRD CARBON KEVLAR COOLING PLATE
PASSWORD CARBON KEVLAR SPARK COVER
PASSWORD CARBON KEVLAR ECU COVER
PASSWORD CARBON KEVLAR FUSE BOX COVER
SPOON RES COVERS
SKUNK OIL CAP
WHITE VALVE COVER
ThpoonThports
http://www.8thcivic.com/forums/car-builds/293462-we-showin-they-goin-g-i-chos-gangsta-grey-mustache-ride.html#post10616010
Mod List:
Engine/Performance Modifications
Skunk2 3.5" Polymer CAI
USDM Mugen Quick Shifter
Hybrid Racing Shifter Base Bushings
Invidia Q300
SSR 4-2-1 Race Header
P2R Throttle Body Spacer with 2 Gaskets
Hasport Rear Mount 70A
3M Injected Dogbone mount
Hondata FlashPro
Tuned by VitViper
Meyle Platinum brake rotors
Stoptech street pads
NGK Iridium 7 Spark Plugs
Spoon Monoblock Calipers
Wheel/Suspension Upgrades
Koni STR.T Front Struts
Koni Sport Rear Shocks
Neuspeed Sport Springs
Godspeed Camber Arms
Ingalls Front Camber Bolts
Beaks Candy Red Rear Lower Tie Bar
Summer Wheels: ADVAN RG-D 17 x 8.5 + 33
Summer Tires: Falken Azenis 453
Winter Wheels: Enkei Stock Evo8 17 x 8 +38
Powdercoated True White
Winter Tires: Continental ExtremeContact DWS 225/45
Exterior Modifications
20% Tint all around
OEM Window Visors
09 Front Conversion
09 HFP Front Lip
09 OEM Fogs
Nokya Yellow Fogs
Nokya Yellow DRLs
Front and Rear JDM Badges
EGR Rear Roof Visor
RX330 Retrofitted Headlights w/color mod and E46 shrouds
Gloss Black Roof Vinyl
Mugen Rep Side Skirts
USDM OEM Mugen Rear Diffuser
USDM OEM Mugen Wing
43 LED Rain Light
iJDMtoy Projector Reverse Lights
VIS Carbon Fiber Civic RR Hood Color Matched GGM
"DOHCK20Z3" Side Decals (removed iVtec decals)
Digital Camo Hydro dipped Valve cover, fuse box cover and ecu cover. All with Mercedes Silver Base Coat.
Interior Modifications
CTR Shift Boot
Blox "Limited Series" 490 Spherical shift knob Neochrome
Interior LED Map/Dome Lights
CorSport red "H"
Strut King Dead Pedal
Broadway Mirror
OEM All Weather Mats
I.C.E
2 10" Alpine Type E
Rockford Fosgate 1000w Amp
Instagram @fg2taffysi
Photo Credit The Sauce Spot
Engine / Performance Modifications
*Ct-Engineering Supercharger
*IMT Custom Blower Pulley
*IMT Big Bore Inlet
*IMT Kool Boost 2.25 Charge-Air Cooler
*IMT Custom High Density Core
*IMT 1.00" Thick Phenolic Supercharger Spacer
*k24 Crank Pulley
*Hybrid Racing Fuel Rail
*Hybrid Racing Fuel Pressure Gauge
*Hybrid Racing Shifter Cable Bushings
*Hybrid Racing Slim oil cap
*Hybrid Racing Coolant Temp Sensor Adapter (used for idle air assist delete)
*Hybrid Racing Reservoir Cover
*Injector Dynamics 1000 cc Injectors
*Hondata FlashPro
*Hondata 4 Bar Map Sensor
*Sheepey INC Custom Catch Can
*Speedfactory Tuning & Race Fabrication Custom Coolant Overflow
*T1r race devlopment IAT Sensor
*Walbro 255 fuel pump
*Full Race 3 Inch Exhaust
*Skunk 2 72mm Throttle Body With 80mm Inlet
*Skunk 2 Low Profile Valve Cover Hardware
*Skunk 2 Header
*Custom 3.5 Inch Intake
*Vibrant 3.5 - 3.25 Silicone Reducer
*Vibrant T Clamps
*Aem Dry Filter With Hydro Shield
*Clutchmasters Stage 2 clutch
*All In Fabrication Coil Pack Cover
*Valve Cover Powder Coated Translucent Purple
*Downstar v.3 Black Hardware
*Password Jdm Battery Relocation Kit
*Odyssey 680 Battery
*Comptech Short Shifter
*AEM Wide Band UEGO
*AEM Boost Gauge
*Boomba Racing Motor Mounts
*JDM Dipstick
*Mugen Radiator Cap
Wheels / Suspension Modifications
*17x8 40 offset Enkei Gtc01 Hypersilver
*225 45 17 Nitto Invos
*(Track set up) Team dynamics 15x7 with m&h 24.5 x 8 slicks, m&h 3.6/24 x 15 skinnies on the rear.
*Arp extend wheel studs
*Muteki SR48 Extended Lug Nuts Purple
*D2 coilovers
*SPC Rear Camber Arms
*Beaks Rear Lower Tie Bar
*StopTech Street Performance Brake Pads
*StopTech Drilled & Slotted Rotors
*HFP Front Lip
*JDM Red Emblems
*Trunk De badged
*Grfxp Red Tail Light Overlays
*Grfxp Red Chrome / Black Emblem Overlays
*Front Grill Painted Black
*10k HID Headlights
*3k HID Fogs
*Yellow Fog Light Lenses
*Yellow DRL
*LED License Plate Bulbs
*20% Tint
*Window Visors
*Spoiler Removed
Interior / I.C.E. Modifications
*Skunk 2 Shift Knob
*Red Stitched Shift Boot
*Auto Meter 2 Gauge Panel
*Red Llyod Floor Mats
*Pioneer Double Din Radio
*Pioneer Rear View Camera
*XM Satellite Radio
http://www.8thcivic.com/forums/car-builds/228897-fg2taffysi-build.html#post8794015
1 - 20 of 29 Posts
