who shall be 8thCivic ROTM May??
  • Mikey6p
    Votes: 12 18.5%
  • fg2taffysi
    Votes: 35 53.8%
  • jmetzer03022
    Votes: 18 27.7%
  • Total voters
    65
  • Poll closed .
1 - 20 of 20 Posts
Administrator
:police:
there is to be NO DISCUSSION in this thread. just. vote.
feel free to bump the thread with a "voted" post....but nothing else. NO "VOTED FOR _____" posts.
:readtherules:
Administrator
http://www.8thcivic.com/forums/car-builds/121423-mikey6ps-asm-fa5.html
Purchase Date: 7-7-08
Paid Off: 9-5-12
Modifications:
Performance:
  • Custom 3" Intake
  • GoPower 3" v3 "Quiet" Exhaust
  • J35 Throttle Body
  • Ported Intake Manifold
  • Exedy KHC10 OEM replacement clutch
  • FD2 5.062 Final Drive
  • P2R Throttle Body Spacer and Thermal Gaskets
  • P2R Intake Manifold Gasket
  • Hondata FlashPro, tuned by VitViper
  • Hybrid Racing Transmission Bushings
Suspension:
  • 18x9.5+32 Custom 2-Piece Step Lip 6061 Barrel Super Advans SA3R
  • 235/40/18 Bridgestone Potenza RE760 Sport
  • Koni Sport Yellow Shocks
  • SteebSpecd Spring and Sleeve Setup, XXX F / 14k Rear
  • SPC Front Camber Bolts
  • Buddy Club Rear Camber Arms
  • Progress Rear Sway Bar
  • DIY super heavy duty endlinks
  • Hawk HPS brake pads
  • ABT Drilled/Slotted Rotors
  • Pentosin Super DOT4 Brake Fluid
Exterior:
  • 17% tint
  • Mugen Window Visors
  • VIS "doluck" CF trunk
  • DEPO FD tails
  • RR Fender Flares
  • Replica Mugen Sideskirts
  • JDM emblems with Blue Grafxpression overlays
  • Skunk2 Valve Cover Hardware
  • DEPO FD1 headlights, retrofitted
  • -Tsx Projectors
  • -Orbit Shrouds
  • -Bezel Painted Black
  • -Shroud Painted Silver
  • -Philips 85122+ Bulbs
  • Morimoto 55w 5000k Ballasts/Harness
  • VIS Fenders/bumper/hood
  • FD2 Sidemarkers
Interior:
  • Pioneer AVIC D3 Head unit/Ipod Connection/Bluetooth unit
  • Wink Mirror
  • CSX Center Bin
  • TWM M1 Abrams Shift Knob
  • Corsport Short Shifter
  • Corsport Shifter Base Bushings
  • Corsport Rear Pillar Bar
  • Red door panel inserts
Instagram @fg2taffysi
Photo Credit The Sauce Spot
Engine / Performance Modifications
*IMT Custom Blower Pulley
*IMT Big Bore Inlet
*IMT Kool Boost 2.25 Charge-Air Cooler
*IMT Custom High Density Core
*IMT 1.00" Thick Phenolic Supercharger Spacer
*IMT Heat Exchanger
*Hybrid Racing Fuel Rail
*Hybrid Racing Fuel Pressure Gauge
*Hybrid Racing Shifter Cable Bushings
*Hybrid Racing Slim oil cap
*Hybrid Racing Coolant Temp Sensor Adapter (used for idle air assist delete)
*Hybrid Racing Reservoir Cover
*Wire-Worx Engine Harness
*Wire-Worx Ground Wires
*Skunk 2 72mm Throttle Body With 80mm Inlet
*Skunk 2 Low Profile Valve Cover Hardware
*Skunk 2 Mega Power Header
*Skunk 2 Intake Manifold Gasket
*Skunk 2 Short Shifter
*Ct-Engineering Supercharger Manifold Powder Coated Super Chrome
*Ct-Engineering Idler Pulley Bracket & Pulleys
*Speed Factory Racing Polished Coil Pack Cover
*Speedfactory Tuning & Race Fabrication Custom Coolant Overflow
*Injector Dynamics 1000 cc Injectors
*Hondata FlashPro
*Hondata 4 Bar Map Sensor
*Sheepey INC Custom Catch Can
*Trac Tuff Water By Pass Adapter
*T1r race devlopment IAT Sensor
*k24 Crank Pulley
*Walbro 255 fuel pump
*Full Race 3 Inch Exhaust
*Custom 3.5 Inch Intake
*Vibrant 3.5 - 3.25 Silicone Reducer
*Vibrant T Clamps
*Vibrant -An Fittings
*Vibrant -An Braided Hose
*Aem Dry Filter With Hydro Shield
*Clutchmasters Stage 2 clutch
*Valve Cover Powder Coated Black Chrome
*Motor Mounts Powder Coated Super Chrome
*Downstar v.3 Black Hardware - on coil pack cover, coolant fill neck, coolant overflow, radiator bracket, upper radiator support, fenders, hood hinge, ground wires, ac line bracket
*Downstar Motor Mount Bolts - with black beauty washers
*Downstar Supercharger Manifold Bolts - with black beauty washers
*Downstar Idler Pulley Bracket Bolts -with black beauty washers
*Downstar Water Bypass Adapter Bolts - with black beauty washers
*Password Jdm Battery Relocation Kit
*Odyssey 680 Battery
*AEM Wide Band UEGO
*AEM Boost Gauge
*Boomba Racing Motor Mounts
*JDM Dipstick
*Mugen Radiator Cap
Wheels / Suspension Modifications
*17x8 40 offset Enkei Gtc01 Hypersilver
*225 45 17 Nitto Invos
*(Track set up) Team dynamics 15x7 with m&h 24.5 x 8 slicks, m&h 3.6/24 x 15 skinnies on the rear.
*Arp extend wheel studs
*949 Racing Extended Lug Nuts
*D2 coilovers
*SPC Rear Camber Arms
*Beaks Rear Lower Tie Bar
*StopTech Street Performance Brake Pads
*StopTech Drilled & Slotted Rotors
Exterior Modifications
*HFP Front Lip
*JDM Red Emblems
*Trunk De badged
*Grfxp Red Tail Light Overlays
*Grfxp Red Chrome / Black Emblem Overlays
*Front Grill Painted Black
*10k HID Headlights
*3k HID Fogs
*Yellow Fog Light Lenses
*Yellow DRL
*LED License Plate Bulbs
*20% Tint
*Window Visors
*Clear 3rd Brake Light
Interior / I.C.E. Modifications
*Hybrid Racing Shift Knob
*Grfxp 3.5 inch Shifter Extender
*Red Stitched Shift Boot
*Auto Meter 2 Gauge Panel
*Joes Racing Switch Panel
*Red Llyod Floor Mats
*Pioneer Double Din Radio
*Pioneer Rear View Camera
http://www.8thcivic.com/forums/car-builds/228897-fg2taffysi-build.html
Engine/Performance Modifications
*Invidia Header
*Invidia Q300 exhaust
*Rick Spec'd 3.5" CAI
*Vibrant Filter
*Injen Hydro Shield
*CT Engineering Stage 2 Supercharger
*CT 3.15" pully
*Ported Blower Manifold
*Ported Ct Inlet
*Throttle Body Coolant Bypass Mod
*CT 520cc injectors
*P2R Thermal Intake Manifold Gasket
*Injected Torque Mounts
*NGK BKR8EIX Spark Plugs
*Gatorback belt
*OEM Clutch
*Napa 7777 Upper Radiator Hose
*CT Engineering Carbon Fiber Fuel Rail Cover
*Wrinkle Red Valve Cover
*JDM Black Dipstick
*Rick Spec'd OEM Battery Relocater
*Hondata Flashpro
* Tuned by Vit Viper
Wheel/Suspension Upgrades
*17x9 +22 Enkei RPF1 silver
* 205/40/17 Faulken Ziex 912
*Skunk2 Pro-C Full Coilovers
*SPC front Camber Bolts
*Muteki Black SR48 Lugnuts
*OEM crystal Black Pearl
*OEM HFP Front Lip
*JDM red "H" Emblems
*Shaved "civic" Emblem
*Color Matched Licence Plate Trunk Trim
*30% Tint All Around
*Rolled Fenders
*Rolled Rear Quarters
*LED licence Plate Bulbs
*OEM Fogs
Interior Modifications
*Hybrid Racing Adjustable Short Shifter
*Moddiction Anvil 2 Shift Knob Polished
*Redlinegoods Leather Shift Boot
*J's Racing JDM Steering Wheel Emblem
*OEM Red H Key Fob Backing
*LED interior Lights
*Strutking Deadrest Pedal
1 - 20 of 20 Posts
