who shall be 8thCivic ROTM March?
  • jrickerm
    Votes: 4 2.5%
  • Carter
    Votes: 19 11.9%
  • the sled
    Votes: 45 28.1%
  • Jadedfg2
    Votes: 72 45.0%
  • 0720Steve
    Votes: 20 12.5%
  • Total voters
    160
  • Poll closed .
1 - 20 of 23 Posts
2007 FA5 Daily Driver + Track + Autocross
“It’s still cheaper than therapy”
Power
343 whp/235 tq DynaPack
332 whp/246 tq edyno
Engine
Hondata Flashpro
e-tunez by VitViper
Jackson Racing supercharger
Pulley Boys 3" pulley
Injen cold air intake
J35 throttle body w/P2R thermal gasket
Vibrant race header, no cat
Invidia Q300 catback
Denso IK24 plugs
ID 725cc injectors
Walbro 255 fuel pump
Custom water/meth injection 16 gph, stealth 1 gal reservoir (engine bay)
5 gal water/meth trunk tank (track days only)
3M injected mounts
Catch can and drilled PCV
Exedy Stage 2 clutch
ACT Streetlite (11.4 lb) flywheel
Torco MTF/RTF (DD/track)
MFactory magnetic drain plugs (oil & tranny)
NAPA 7777 upper rad hose
Earl's oil cooler, AN-8 lines and fittings, Mocal thermostat
Vit & Jay's Boost By Gear launch control
Modified OBD1 IAT sensor after JRSC and MAF delete
Custom carbon fiber battery cover (to hide my fugly green Interstate)
Wheels/Tires
Summer
Dunlop Direzza Star Spec 225/45R17
Motegi Traklite v1 17x8 +45, 6.7 kg
McGard Spline Drive lugs
Winter
Bridgestone RE960 Pole Position 215/45R17
Stock rims
Suspension
Progress rear sway bar
Koni sport dampers, Neuspeed sport springs - Redshift built
Buddy Club P1 Racing front lower ball joints
Full Race spherical LCA bushings (new stainless stl version)
SPC front camber bolts - 2 sets
Ingalls rear camber plates
Brakes
Hawk HPS pads (front/rear, DD and autox)
Hawk DTC 60 pads (front only, track days)
TSX brake swap - Acura front calipers and Brembo front rotors
Goodridge SS brake lines
Speedbleeders
ATE Superblue DOT4 brake fluid
Custom brake ducting with air dam (track days only)
Exterior
K2 fogs w/Lexan
Almost legal window tint
Lime Rock Park track map sticker
Civic Hybrid underbody aero panels
GodSpeed Project folding front tow hook (track days only)
Interior
Extra 12V accessory power socket near hood release for GPS
XLR8 pod V2
AEM wideband w/B29 ECU pin to FP
AEM oil pressure gauge w/Blox Racing adapter plate
Water/meth flow sensor & indicator light on dash
Need mo gauges! Torque Pro on the Android w/OBD2 Bluetooth
HER NAME:Miss Jackson
ENGINE MODS:
Jackson Racing Supercharger
Stiegemeier Ported + Polished Supercharger
Stiegemeier Ported + Polished Supcharger Manifold
Stiegemeier Venom Cooler for JRSC
MercRacing Stage 2 Aftercooler
MercRacing Jackson Racing Inlet
Pulleyboys 3.0 Blower Pulley
2012 Si K24 Crank Pulley "13810-R40-A02"
Hondata Flashpro w/ Full Tune by "VipViper"
VitViper's Boost By Gear
Omni 4 Bar Map Sensor
Comp Clutch Stage 4 w/ Flywheel
J37 Acura ZDX Big Bore Throttle Body w/ P2R Adapter Plate
Injector Dynamics 1000cc Fuel Injectors
DeatschWerks Fuel Pump
Skunk 2 Alpha Header w/ Blox 2.5" donut gasket
Skunk 2 Silicone Lower Radiator Hose
Skunk 2 Radiator Cap
Skunk 2 Magnetic Trans/Oil Pan Drain Plugs
Skunk 2 Black Flat Washer Valve Cover Kit
Import DPS 3.5 Cold Air Intake w/ Hydro Shield
Import DPS Catch Can
Napa (#7777 Upper Radiator Hose)
3" Full-Race Exhaust System
Hybrid-Racing Gold Fuel Rail w/ Russel Fuel Gauge
Hybrid-Racing Black Oil Cap
Hybrid-Racing Shifter & Base Bushings
Hybrid-Racing EM1 CMC w/ SS Clutch Line
Innovative 75A Motor Mounts
Hasport Rear Lower Motor Mount
Powder Coated Valve Cover
Red Shocker Battery Tie Down
Password JDM Battery Relocation Kit
NGK Iridium BKR9EIX 2669 Spark Plugs
T1R IAT Sensor
INTERIOR MODS:
TWM Stage 2 Short Shifter (LOVE IT)
Password JDM Billet Shift Knob
Red Bride Shift Boot
AEM Wideband UEGO A/F Ratio Gauge
Marshall White LED Boost Gauge
XLR8 Dual Gauge Pod
7" JVC Touchscreen DVD/CD/USB/NAVI/IPOD Connections
Two 10" 4 Ohm Audiobahn Sub-woofers
Audiobahn 1,200 watt Amp
Power capacitor
20% Tinted Windows
Blue LED Map Lights
007 Garage Door Opener
JDM Red Steering Wheel Emblem
JDM Red Key Fob Cover
Strut King Dead Pedal Cover
Black/Red Stitched Matching Car seat lol (4 Lil Pimpin)
Hybrid-Racing Awesome Sauce!
EXTERIOR MODS:
05-06 RSX Type-S Rims Painted White 225/45/17
HFP Front Lip from CHH
Red JDM Honda Emblems (Front + Rear)
De-Badged Civic, SI Emblems
6000k HID Kit
Yellow Fog Light Kit
Yellow Nokya DRL's
Ruby Red Taillight Overlays From GRXP
Strut King Front Tag Relocator
SUSPENSION
BC Racing Coilovers 8K/6K Spring Rate
Skunk 2 Gold Rear Camber Arms
Megan Racing Lower Tie Bar
Slotted / Cross Drilled Rotors (Front+Rear)
Front / Rear Fenders Rolled
http://www.8thcivic.com/forums/car-builds/289428-carterz-whats-black-crys-lot-build-thread.html
2007 Civic Si Sedan Navi
Engine:
438whp/271ft/lb 13.5 psi
Kraftwerks Rotrex C30-94 supercharger kit
Custom 3.5" intake
Xenocron IAT sensor/flange
2010 MDX throttle body w/P2R adapter & thermal gaskets
SpeedFactory 4 Bar MAP sensor
Fuel Injector Clinic 1100cc injectors
2008 TSX cams
2012 TSX Timing Chain Tensioner
Buddy Club race header
3" exhaust
Deatschwerks DW65c fuel pump
Crushed fuel pressure regulator
E85
Flashpro tuned by Kenny "Turbogixxer Tuning"
Hasport U94A mounts
Competition Clutch stage 4 kit
Hybrid-racing shifter cable and base bushings
Custom battery relocate
Shaved valve cover painted wrinkle black
Custom coil pack cover painted wrinkle black
K-tuned billet plate
Skunk2 black low profile valve cover bolts
Hybrid Racing black slim oil cap
JDM black dipstick
Suspension:
Buddy Club RaceSpec coil overs with pillow ball mounts
Buddy Club front extended ball joints
Buddy Club rear camber kit
Energy suspension front LCA bushings
Blox rigid collar kit
Wheels:
ARP extended wheel studs front
Buddy Club SF 17x7 +35 Gunmetallic
Buddy Club Gunmetallic lugnuts
Nitro NeoGen 215/45/17
OEM wheels
BFG T/A Drag Radial 225/45/17
Spin Werkes 15x8
Sickspeed neochrome spiked lugnuts
M/H 24.5x8.5
Exterior:
HFP front lip
McCulloch 6000K HID's
Nokya 2500K halogen DRL/HI
LED reverse bulbs
Custom driver headlight intake hole
OEM black grille
Mugen window visors
OEM splash guards
1" NeoChrome hood spacers w/washers
ZERG Industries hood dampers
Custom Lexan rear window
Interior:
AEM digital A/F gauge
AEM digital boost gauge
XLR8 gauge pod
JDM hazard switch
JDM Type R key cover
Buddy Club Type A black shift knob
2009 shifter assembly w/Hybrid-racing shifter base bushings
2008 red stitched OEM shift boot
LED dome lights
aka 3 blocks!
Jadedfg2
Engine/Performance Modifications
Drag Cartel 2.2 Cams
Supertech spring & retainer kit
Supertech standard size flat valves
TracTuff timing chain cover baffle
TracTuff K20a pump w/z3 pickup
TracTuff baffled oil pan
Skunk2 int. mani.
Skunk2 72mm Tb
Hybrid-racing CAI prototype
Exedy lite flywheel
Exedy stg.1 clutch
Mtec shift lever springs
Hybrid-racing shift cable bushings
Hybrid-racing Short shifter w/extended rod
Hybrid-racing EM1 cmc
Skunk2 alpha header
Full-race 3 in. exh.
DeatschWerks 600cc inj.
Ktuned adj. pulley
Ktuned upper coolant housing
Ktuned fuel rail
Ktuned iac delete
Mishimoto radiator
Hasport 88a eng. mounts
ultimate racing front mount inserts
Spoon subframe ridgid collars
Wheels/Suspension
Polished Mugen Gp's reverse staggered S2000 spec
Fr. 17x8.5 Rr. 17x7.5
Falken Azenis RT615k Fr. 235/40 Rr. 215/45
KW V.3 w/redshift race spring conversion
Asr camber plates
Cusco swaybars Fr.& Rr.
Skunk2 camber arms
T1R roll center adapters
Powerslot rotors Fr.&Rr. Hawk hps pads
Ichiba V2 25mm spacers rear & 30mm front
Beaks crossbar
Exterior Modifications
Shell gutted & sprayed Jade green metallic
Fenders rolled&pulled Quarter panels rolled
Ap1 retrofit done by customlightz
09 conversion w/lip
Pwjdm dry carbon bumper duct
Interior Mods
J's racing CF steering wheel w/Fd2 air bag module
Xlr8 gauge pod w/mtx-l and mtx-d gauges
Mugen pedal assy.
Twm hybrid M1 shift knob
Honda fit gd3 shift boot
JL audio w6 stealthbox and xd600/1 amp
http://www.8thcivic.com/forums/car-builds/309977-jadedfg2s-jade-green-fg2.html
Administrator
Discussion Starter #6
CT-E Supercharger, Rebuilt and Ported by Stiegemeier
3” Pulley Boys Blower Pulley
5.98” CRV Crank Pulley
Uncle Dabe Spec 3.5” CAI w/ Injen filter (X-1021-BR)
3.7 RL SH-AWD 80mm TB
IMT Inlet
IMT Stage 1 Aftercooler
GoPower 750cc Injectors
Hondata 4Bar Map
T1 IAT
DeatschWerks DW65c Fuel Pump
06-08 TSX cams
Skunk2 Megapower RH
Invidia Q300
VitViper BBG
Hondata Flashpro tuned by VitViper
Innovative Motor Mounts 75A
Hasport Rear Mount 70A
JDM Red Valve Cover w/Black Oil Dipstick
Wheel/Suspension Upgrades
Mugen GP w/Firehawk 225/40/18
TSX Front Brakes
Buddy Club N+ SPEC DAMPER
Buddy Club P1-RACING rear camber kit
Progress Rear Sway Bar
HFP Underbody Spoiler Kit
HFP Window Visors
4300 HID
OEM EX Sedan Foglights
EF Sidemarkers
EG SiR LSD Decal
EX Trunk Swap (wingless)
Chinese FA Taillights w/amber (finally OEM!)
Redline Tuning QuickLIFT Elite Hood Damper
Debadged Civic and Si Emblems
Interior Modifications
CSX Sliding Cover Cubby
CSX Center Console Drink Holder
TWM Stage 2 Short Shifter Assembly
S2000 Titanium Shift Knob
FN2 Shift boot
CTR Push Button Start
CTR Hazard
09 LX-S Rear Speaker Shelf (3rd brake light)
"I.C.E"
OEM Navigation
0720Steve's SC08TWFA5
1 - 20 of 23 Posts
