who shall be 8thCivic ROTM April??
  • OBX4life
    Votes: 50 61.7%
  • 86kredlinesi
    Votes: 31 38.3%
  • Total voters
    81
  • Poll closed .
1 - 19 of 19 Posts
Administrator
:police:
there is to be NO DISCUSSION in this thread. just. vote.
feel free to bump the thread with a "voted" post....but nothing else. NO "VOTED FOR _____" posts.
:readtherules:
Dirt Nasty Low
http://www.8thcivic.com/forums/turbocharging/370049-hashtag-wiggle-sneezy-tropicana-project.html
Engine/Performance Modifications
  • Synapse tubular manifold
  • Synpase 3" downpipe w/ recirculated waste gate
  • Synapse 2.5" charge piping (powdercoated black)
  • Synapse vertical flow intercooler
  • GTX3071r, .82 housing
  • TurboSmart Raceport BOV
  • TurboSmart Hypergate waste gate
  • Exedy stage 1 organic clutch
  • Resurfaced OEM flywheel
  • MAC 4-port boost control solenoid
  • Hondata 4bar MAP sensor
  • NGK-BKR9EIX spark plugs
  • Napa 7777 radiator hose
  • Mucter's "No-Nonsense" fuel return (Article here)
  • VitViper vacuum block w/ PTC fittings & lines
  • Deatschwerks EV14 1000cc injectors
  • Deatschwerks dw300lph fuel pump
  • Hasport 70A motor mounts
  • Thermal R&D 3" exhaust
  • Uni 3/8 NPT breather filter
  • DIY polished AC lines
  • Hondata Flashpro tuned by VitViper
Wheel/Suspension Upgrades
  • BC N+ Coilovers
  • Energy Suspension prothane LCA bushings
  • Ingalls front camber bolts
  • Ingalls rear camber sliders
  • 17X8 +38 Evo 8 rims powder coated Lexus pearl white
  • Yokahama S-Drive 235/40/17
Exterior Modifications
  • Shaved "civic" emblem
  • Mini H1 Projector retrofit w/ Gatling shrouds
  • Morimoto 3five HID fog kit (5000k)
  • IxizConcept hood damper
  • I-vtec Turbo OEM Acura intake manifold cover
  • LED license plate lights made by Ethlar
  • Blacked out rear Honda emblem & trunk trim
  • Custom black I-vtec DOHC side panel decals
  • Custom "Evo Style" license plate re-locator
Interior Modifications
  • AEM true boost/EUGO wideband gauges
  • XLR8 V2 Gauge Pod
  • 35% 3M color-stable all the way around
  • CTR shift knob
  • Strutking dead pedal
  • Domo Powaaahhh
  • Bride shift-boot
  • OEM interior courtesy lights swapped to red LEDs
  • Recaro red door inserts
  • Pioneer F700BT Nav/Bluetooth Head Unit
Skunk2/Kraftwerks Project SI
Modification List
Kraftwerks Supercharger Kit
Skunk2 Megapower RR Exhaust
Skunk2 Megapower Header
Skunk2 Pro-C Coilovers
Skunk2 Rear Camber Kit
Skunk2 Rear Tie Bar
Skunk2 Pro DBW Throttle
Skunk2 Tuner Cams
Skunk2 Composite Fuel Rail
Skunk2 Radiator Cap
Skunk2 Magnetic Oil Plugs Engine/Tranny
Skunk2 CAI customized to fit Kraftwerks Supercharger kit
Skunk2 Low profile valve cover bolts
Skunk2 Radiator Hoses
Skunk2 Oil Cap
Skunk2 Battery Tie Down
Skunk2 Radiator Cap
Skunk2 Thermal Gaskets Throttle/Intake Manifold
Skunk2 Six Speed Shift Knob
Skunk2 Reservoir Covers
Skunk2 Velocity Stack
Skunk2 License/Plate Cover
Kraftwerks License Plate Cover
Mugen Civic Type RR Shifter
Ported/Polished Kraftwerks Intake Manifold
Innovative Engine Mounts Race Edition 85A Urethane
HPD Racing Rear Sway Bar
HPD Sway Bar Bushings Front/Back
Hondata Flash Pro
Hondata MAP Sensor
Optima Yellow Battery
Rockford Fosgate T1 12's
Rockford Fosgate Mono 1000W Amp
Rockford Fosgate 1 Farad Cap
Pioneer 4 way 6.5’ front speakers
Custom Subwoofer Rack cover in Black Suede
Honda Civic SI Taffeta White Wheels
Mogeti SP10 Gun Metal Wheels wrap on BFGoodrich G-force drag Radials
Pearlescent White Valve cover and Intake pipes
Spec Clutch Stage 3+
DeatschWerks DW65c In-Tank Fuel Pump
Grams Performance Injectors 1000CC
Hasport Rear Engine Mount 93A Urethane
Turbosmart Dual Bypass Valve
Corport Shifter Aluminum Bushings
NGK BKR7EIX-11 Iridium IX Spark Plugs
DEI Titanium Exhaust Wraps
Vit Viper Vaccum Block
Innovate MTX Series Boost/Shift Gauge
Mishimoto coupler
Mishimoto Hose Clamps
Mishimoto Baffeld Oil Catch Can
Honda JDM dipstick
Honda Oxygen Sensor extension(special order to fit Skunk2 Header without cutting and extending wires)
Carbon Fiber Mugen Si Front lip
Mugen RR side skirts and rear lip with brake light
Modulo rear spoiler
Mugen window visors
Dirt Nasty Low
Vowteed :party:
1 - 19 of 19 Posts
