1 - 4 of 4 Posts
im getting a vibration...thought it was my bent rim but no, helped a little after i put snother rim on, but it didnt...i did a tire rotation and didnt rebalance the fronts that went to the back...would this be my issue?
Get them balanced at a local tire shop. Make sure the mechanic is watching the tire while it's spinning to inspect the tread and wheel. One of your tires may be separating, or a wheel may be warped slightly. If mechanics aren't watching closely and doing proper inspections, they can actually balance a bad tire and put it back on your car! Check the tires and wheels first, and if that doesn't fix it the next thing to check is bearings, ball joints, CV Axles, then Suspension.
1 - 4 of 4 Posts
