1 - 1 of 1 Posts
In stock and ready to go, fits 2006-2010 Civic/Civic Si
One of the best known names in the stainless steel brake line industry,
Goodridge Brake Lines
are designed to DOT certification and TUV approval and undergo a 9-point quality inspection and testing to 3000psi prior to release. They feature all the necessary fittings and brackets for a direct, bolt-on installation and are backed by Goodridge's 'Forever Guarantee'. Sold as a complete set of all 4 lines. Firms up your pedal, and resists corrossion, expansion due to heat and reduces the overall lazy pedal vs the soft OEM rubber lines
Priced @ just $111.00 shipped in the 48 states!
For a complete solution, we can also package these with Motul high performance brake fluid and a Motive Speed Bleeder! Check it out:
Motul Brake Fluid
Brake fluid is one of those things that very few people bother thinking about, even fewer people ever change, but which is VITAL towards overall brake performance! Brake fluid is hygroscopic, which means it absorbs moisture. As moisture is absorbed, through condensation, etc., the boiling point of the brake fluid is dramatically reduced. That means it takes less heat to over tax the brake fluid, which can lead to a soft pedal, and brakes that are very fast to fade. Motul's fluid features a very high wet and dry boiling temperature due to it's 100% synthetic composition. Fully compatible with your stock Civic master and slave cylinders, and works perfectly with the factory ABS. This fluid is suitable for street or track use. We suggest completely flushing your brakes once a year (more if you use your car in competition) for maximum efficiency.
It will take 3 bottles of Motul to completely flush your brakes/clutch fluid - $70 shipped in the 48 states
Bleeding brakes by yourself is impossible - it usually takes 2 people. One to be in the car pumping the pedal and one at the caliper, cracking the nut to let the air out. Not anymore!! The Motive Power Bleeder is an innovative and simple way to bleed your vehicle's power braking system. Simply fill the cannister, open the bleeders one at a time, and pump the fluid into a container or the optional no-mess Motive Catch Bottles. It's that easy! This is a professional grade product at a fraction of the price. Also offered is the catch tank, which Attaches to the brake bleed screw and catches fluid to eliminate messes. Includes a hanging hook to hang from the chassis for convenience
Once you guys use this, you will wonder how you ever got along without it - it's simply that good!
Motive Bleeder - $71 shipped in the 48 states; with catch tank (to catch the nasty brake fluid overflow that comes out of your lines) - $95 shipped
COMBO DEAL!!!!
#1. Goodridge Brake Lines + 3 bottles Motul high performance brake fluid + Motive Bleeder - Combo Priced @ $229 shipped in the 48 states.
#2. Goodridge Brake Lines + 3 bottles Motul high performance brake fluid + Motive Bleeder + Catch Tank - Combo Priced @ $250 shipped in the 48 states.
To order, just give us a call, or pm us with your email address
Thanks!
1 - 1 of 1 Posts
