1 - 20 of 21 Posts
Hey all,
I'm curious to know if there is a way to get both doors in the si coupe to unlock when I remove the key from the ignition. Right now, only the driver's door unlocks. I can't find my manual but i think it may be in there.
Can anyone help?
Yes there is a way and it is in the complete owners manual and that small little one they give you also.
There is a sequence you have to do while holding the lock/unlock button for something like 10 seconds and the car has to be in Auxiliary mode (key turned to second position)
Discussion Starter · #4 ·
thanks, i figured it out; you have to open the door, make sure the parking brake is applied, put key in position III, then hold down the bottom of the lock/unlock button until you hear three clicks (roughly10 seconds) then move key to position II, (wait 2 secs) then move key to position I and out.
wait, hold down lock and unlock buttons? we have 2 diff buttons on our key for lock and unlock...
can someone confirm this?
I didn't have to open the door. Turn the key to the "ON" position, hold the unlock button for 10 seconds. After 5 seconds you will hear one click, wait for 5 more for the second click. Within 5 seconds of the second click, turn the car off and remove the key.
Damn you 2006!
I can't find it in the ******* manual. Someone just tell me how to do it, I have a 07 Civic Si sedan
close doors, apply parking brake, turn key to ON position (when all the sensor lights in dash turn on), hold unlock button on driver door until you hear 2 clicks...should sound like the lock is cycling. roughly 5 sec in between each click. Then turn key to (I) or the radio only position, then off...then just test to make sure it works.
**Side Note** Works with the auto up and auto down feature on the driver window..same process...except it turns the auto down on and off..that's all
Does this work if you have an '06, too?
Nope. :[
Turn it to the On position but don't actually turn the car on right?
1 - 20 of 21 Posts
