181 - 199 of 199 Posts
· Registered
this is a great thread but i still have a question..
theres no further modifications needed to get these camshafts running in the k20z3 other than taking the old camshafts out and putting these in?
my next few questions are a little off topic but still relate a little.
right now with just an invidia header and injen cai my duty on datalogs is topping off at 83 around 8300 rpms. i do plan on getting a rrc and tsx throttle body in there before the tsx cams. do i need to upgrade my injectors? and if i put rdx injectors in do i need a fuel pump? this is a daily driver too im not racing it or anything.
thanks for the help!
· Registered
It looks from the picture linked before that it is on the exhaust camshaft only. The intake camshaft only has a single ring :thumb:
I've got a set of k24 cams from either a accord or crv. Both cams have single rings. What exactly they out off? And will they do any good on my 07 si? Intake cam is stamped RB. Exhaust R5
· Registered
Flashpro should be your first initial purchase. great way to free up some restrictions from the factory..
I have been in debate on getting the TSX cams myself. We just dropped an 08 tsx swap in my roomates RSX and he loses power around 7k. Plans on modifying the VTC gear to 47 degrees to extend the range.. Is the powerband still to 8k using the z3 gears?
Would it be bad if you didn't have a flash pro and still got these cams?
· Registered
So if u use a tsx cam in the stock engine I'm going to lose power after 8k? How do I extend it ?
· Registered
Hi,
Im interested in purchasing a set of 2006-2008 tsx intake and exhaust cams. Im new to cams, so any help would be appreciated.
Current Modifications:
-2008 Civic Si Sedan
-stock k20 engine
-AEM CAI V2
-Skunk2 header
-Fullrace 3" exhaust
-boomba motor mounts
-flashpro
my questions are:
-are tsx cams drop and go? no other engine mods needed? (aside from flashpro of course)
-how much do these cost brand new?
-whats a reputable place/website to you buy these from?
-how much do they cost to install?
-if you have a similar setup as mine, what performance gains did you make? feel free to share any dyno results
-how will these perform with a stage 2 supercharger?
-how will these perform with a skunk2 intake manifold and throttle body?
-how do these cams effect fuel economy?
thanks for your help. :dance:
Hi,
-stock k20 engine
-AEM CAI V2
-Skunk2 header
-flashpro
my questions are:
Does running tsx cams make any difference to ur car? Lmk! Planning to get some! And what year of the Tsx cams should I get thx.
