why dont you try it first, and if it works, you can write a how to... If it ***** up your motor, shame on you for not searching....
try this...
google.com
yahoo.com
msn.com
:thumb:
try this...
google.com
yahoo.com
msn.com
:thumb:
Sorry so far this answer is as close to your question as I can find. I hope this leads you in the right direction.The two engines share an almost identical head design. Cams are interchangeable, so any Cam made for the K20 will fit the K24. Higher lift camshafts require better valve springs, retainers and spring seats.
Then WTF are our cams? I thought we had the same ****?sickyute said:u can get 06 RSX-S cams...they are type r cams.
don't even know if i'll be at the show....but my car will be there for sure.blackfg2 said:Ill be at that show too....hopefully with everything done also....Ill see you there we should post up next to each other at the show:thumb:
we have a unique cam setup that only the z3 has(can't remember if it's intake or exhaust)2RotorMotor said:Then WTF are our cams? I thought we had the same ****?
sickyute said:we have a unique cam setup that only the z3 has(can't remember if it's intake or exhaust)
and we share the same cams with the 04 RSX(can't remember if it's intake or exhaust)
nice avatar :thumb:06Honda06SI said:http://got-jdm.com/skunk2-pro-series-titanium-exhaust-cam-gear-k20a-k24a-rsx-civic-p-141.html
so these would fit into a 06 si (k20z3 engine)
