1 - 3 of 3 Posts
I have a set of TSX ballasts, it's turning out to be a pain in the ass to connect them to the wire harness I got from XD, so I was debating just spending the 30 bux a pop on the wires that would directly connect to the ballast then cutting the other end and splicing them with the wires from the harness..
however I want to make sure I got the right part #
if I check for the wires on a tsx i cant find them
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=TSX&catcgry2=2005&catcgry3=4DR+TSX&catcgry4=KA5AT&catcgry5=HEADLIGHT&ListAll=All&vinsrch=no
but if I check on an s2000, which i think uses the same ballast, i can find the wire, jsut wnat to make sure before ordering it
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=S2000&catcgry2=2007&catcgry3=2DR+S2000&catcgry4=KA6MT&catcgry5=HEADLIGHT+(2)
that it?
that it?
Xenon depot will send you a type of ballast with one 9006 male and two 9006 females, correct?
splice the 2 9006 females and connect each wire to each of your ballast.
1 - 3 of 3 Posts
