1 - 7 of 7 Posts
trying to replace my license plate bulbs, but i dont wanna snap one of the liner taps (the ones that look like a phillips head)...anyone know how to remove those? thanks
Unscrew the 4 phillips head inserts and the outer part of the clip will then essentially fall out.
edit: oh yeah. When re-inserting them, be careful not to bend the little 'ears' out when inserting the clip back in the hole. You don't have to screw the phillips head part back in, just push it in the hole.
out of the 4 phillips head clips. only one comes out..what do i do about the other 3?
Crap... Worse case, You're gonna have to go buy new ones and break those out.
If you're lucky you can get a mini flat head (or a pick tool if you happen to have one) and, with finesse, lightly pry the middle phillips head part out of the outer snap while unscrewing it. Maybe you just have to give it a little help to start unscrewing.
Good luck!
1 - 7 of 7 Posts
