Civic Trunk latch stuck
TEAM QUICK UPDATE 2012 (LATE):
Followed all of your suggestions, gave me a great place to start.
1) Take out bolt in bottom of back seat (near left center) 12mm socket.
2) Take out bottom seat (with a very small amount of force and manipulating)
3) expose hinge bolt near bottom left of back seat rest
4) remove (very long), can't remember, but I think 12 mm socket as well
5) pry brackets at hinge from left to right seat apart (so seats are no longer hooked together)
6) with a LOT of force, actually bend the back lower right seat (the smaller of the two seats) up and toward the outside of the vehicle like a can opener at the bottom corner of the seat near the hinge (where the bolt used to be).
7) As much as possible, pry the seat back and look in with a flashlight to locate the large seat release lever near the top rear of the trunk driver's side.
8) with a board nearly 2 feet long, reach in with your arm and poke the release for the large seat with the small board.
9) climb into the trunk, and there is a small release lever (manual) that is plastic (usually an off white color with the picture of the trunk of the car) and move it until the trunk opens.
Why didn't Honda give us a key on the outside for this?
