1 - 4 of 4 Posts
so i have had my car bak for the past week or so my problem this morning was i went to start it and it kept stallin out...it has been warm
all week round 70-80 degrees now its blow 50 and had trouble start ha to turn key 10 time after stallin out ..what is the problem here will the ecu fix it self to the weather??? or should i contaxt me tuner?
Sounds like cold start problems. If you have a WB you have a much better chance at figuring this out. Jay and Mike much better at this stuff then me but basically you'll want to datalog before you fire it up. If you do get it to start wait for the o2 sensor to warm up. on the datal log you'll see if its lean or rich. there is a cranking fuels table. thats what you'll be messing with. A little trick that worked for me when it was cold out. I would pull the line off my BOV and spray some starter fluid then it would fire up. that only will work if your too lean.
1 - 4 of 4 Posts
