I decided to change all the mounts on my car today because my engine jerks when giving it gas. Everything went perfectly fine with the install until I attempted to change the transmission mount and discovered something. Turns out when I installed it the transmission mounting bracket (Part #50655-SNA-A80) studs pulled off which sheared the threads inside. I ended up replacing the whole bracket from Honda. After that I threw the transmission mount back in the car and now I have vibration. I did some research and found that aftermarket mounts don't work as well as the OEM ones. The ones I bought were 5 Star so i'm assuming they were good mounts.
For me, it not really a big deal but I would like it gone. The vibration does bug me a bit. Its very noticeable on the transmission side ofc. Any advice would be appreciated. Thanks! (2006 Honda Civic EX)
