1 - 13 of 13 Posts
2008 Si Coupe k24a2 swapped
Just my opinion but if you already have the tranny dropped a stage 1 Exedy is like $300. Might as well throw a new one in there
What would last longer if i were to buy a new stage 3 action clutch or a exedy stage 1 I have plans for turbo in 3-6 months
If you plan on turbo prolly the stage 3 although I’ve seen the exedy stage 1 hold turbo power just fine. Did you not enjoy your stage 3?
244785
Went to get it resurfaced at action clutch in Los Angeles and they said basically my last clutch is shot. Bought a new stage 3 and resurfaced my lightweight flywheel
Discussion Starter · #6 ·
update :
  • bought a new outer casing due to drain plug snapping on me while uninstalling.
  • new clutch release bearing
  • new pilot bearing
  • acuity transmission springs
  • hybrid racing detent springs
  • new 2nd gear
  • syncrotech master rebuild kit on back order atm that’s the only thing keeping me off the road
244790
244786
244787
244788
hey, im planning to swap my 2nd gear .. let me know how it goes... how much you paid for the gear ?
Discussion Starter · #8 ·
I paid 121 for the gear online...honestly found it on Sears believe it or not. All the sleeves etc are getting replaced with the Synchrotech master rebuild kit bro
244791
Discussion Starter · #10 ·
good job man !!! are you doing the job yourself ?
I actually just dropped off my transmission 1 hour ago to be rebuilt by Synchrotech. I opened it up and it just looks too overwhelming and I don’t have a press to get the gears off.
Discussion Starter · #11 ·
Update some pics....
244794
244795
1st and 2nd gear:
The infamous 2nd gear grind...compare to first gears locking teeth..2nd is starting to go..
244796
Here it is circled. This is why I couldn’t get into 2nd. I even have upgraded cmc, bushings on shifter and on trans. Only thing if my trans still doesn’t work is my cables or shifter is shot but there’s just no way so I left it last in my list to check if that’s why I couldn’t get into gear. Anyways I’ve been planning on rebuilding my tranny for awhile.
244797
3rd and 4th
244798
5th and 6th
244799
Discussion Starter · #12 ·
glad to be part of the 8th gen community (even tho I’m super late) I had to experience k series the right way.
1 - 13 of 13 Posts
